Welding Tubes -- What's that cutting helper called!
Old Oct 20, 2010 | 06:29 PM
likwidchz's Avatar
Icon3 Welding Tubes -- What's that cutting helper called!
Howdy,
So I don't know the name of this tool but it goes around a steel tube and has about 300 little steel rods around it so when you want to attach a tube to another tube, like a roll cage or whatever, it allows you to put the tube at the angle desired then slide all these little steel rods against the part and then slide it back and trace out the profile it made on the tube so you can cut it with... whatever means and tig it/weld it?
Name that tool!
--Aaron
Old Oct 20, 2010 | 08:22 PM
9bells's Avatar
OG Fabricator
Default Re: Welding Tubes -- What's that cutting helper called!
Tube template. trick-tools.com
Old Oct 21, 2010 | 04:53 AM
likwidchz's Avatar
thanks!
Old Oct 21, 2010 | 07:16 PM
likwidchz's Avatar
I know its a stupid question , but at 42$/44$ for 1 inch and 1.25 inch PipeMaster's
Granted they look like solid tools to use but humor me I guess what do you all think? any cheaper solutions?
--Aaron
Old Oct 22, 2010 | 10:18 AM
jere's Avatar
How about cutting out a piece of paper?
http://www.gottrikes.com/Tube_Bender.htm
scroll down to the bottom there is a template you can change the size and use
Old Oct 22, 2010 | 11:38 AM
k24em2's Avatar
They are worth the money
Old Oct 22, 2010 | 12:39 PM
9bells's Avatar
OG Fabricator
Absolutely. Time is money folks. How many paper templates can you cut in $40 worth of time? It's not really that much. Honestly though, they might have something cheaper on e-bay if you look. Might find something $10 cheaper.
Old Oct 22, 2010 | 02:42 PM
highroller54's Avatar
spagetti and an elastic?
Old Oct 22, 2010 | 03:36 PM
likwidchz's Avatar
Yeah yeah point taken, I thought id toss it out.
I mean I already spent 3400 on a Miller 200dx and a water cooler! hahaha
Currently working on a stainless steel X brace/bar something rather for the back of my EG for ***** and giggles.
Old Oct 23, 2010 | 09:13 PM
Tyler H's Avatar
I'm usually a fan of having the right tool for the job but... I've had good luck finding straight contours by sticking multiple pieces of welding rod in the edge of corrugated cardboard and pushing it against the desired surface. I used to use that trick to find the shape of the underside of the hood when it was closed to build heat shields. I've done it with plastic coffee stirrers too. I don't see why it wouldn't work if you wrapped it around a tube. Ghetto, I know. But it worked pretty well! =P
racebum
Welding / Fabrication
Jun 28, 2011 01:37 PM
messeduprex
Dec 12, 2008 07:53 PM
TurboEM1
22
May 6, 2007 11:06 AM
MooreBoost
Nov 18, 2004 07:51 PM
_Shadow_
Mar 19, 2002 12:05 PM
