My 95 civic lx 4dr is overheating - disappearing coolant
Old Oct 18, 2010 | 08:46 AM
mndb8's Avatar
Default My 95 civic lx 4dr is overheating - disappearing coolant
well the car is overheating..give a list that you KNOW causes this and i will tell you what i did already...no leaks because there is no fluid on ground everytime but possible leak when i drive..the resevoir fluid keeps disapparing.
mndb8's Avatar
Default Re: please help? overheating
oh its a 95 civic lx 4dr
Old Oct 18, 2010 | 08:58 AM
Former User's Avatar
Let's reverse this guessing game by you telling us exactly what you have already done.
Old Oct 18, 2010 | 09:18 AM
mndb8's Avatar
Default Re: My 95 civic lx 4dr is overheating - disappearing coolant
thermostat changed, head gasket changed multilpe times, bought used radiator, checked if fan started. new water pump..i want to do a coolant flush
Old Oct 19, 2010 | 04:27 PM
mndb8's Avatar
anybody??i thought this forum was good?
Old Oct 19, 2010 | 04:52 PM
redbull-1's Avatar
Get a cooling system pressure test done. If there are no visible external leaks, it may be internal such as cracked sleeve or head.
http://www.trustmymechanic.com/auto-...o-it-yourself/
Old Oct 19, 2010 | 05:01 PM
EJeff8's Avatar
Might have a warped head. But that's an extreme.
Old Oct 19, 2010 | 05:49 PM
When the head gasket was replaced, did you also have the head resurfaced?
Old Oct 19, 2010 | 06:02 PM
fv8s's Avatar
just because you didn't get a response in 30 seconds doesn't mean this forum isnt good. check your head for warpage, bleed the system, watch under the hood while it is running and try to find a visible leak.
Old Oct 19, 2010 | 06:56 PM
ferioLSv's Avatar
is there coolant/water in the oil?
Old Oct 20, 2010 | 09:12 AM
mndb8's Avatar
i will try a pressure check.
no i did not resurface the head i was going to but had to work.
what warpage? sorry! i have blead the system and no water or coolant..don't have ablown head gasket yet
Old Oct 20, 2010 | 09:44 AM
no i did not resurface the head i was going to but had to work...what warpage?...don't have ablown head gasket yet
The point is that if the head was slightly warped but not resurfaced, then this could be your problem.
Old Oct 20, 2010 | 07:57 PM
mndb8's Avatar
i bought it like this. it was like this already..but yea what is warped?
Old Oct 20, 2010 | 08:06 PM
EJeff8's Avatar
Dude, we've said it like three times, your head maybe warped.
tercelrcr
Dec 30, 2014 03:19 PM
DEPintheCurve
15
Sep 9, 2013 01:57 PM
pikes peak
21
May 10, 2010 07:07 AM
j-harts4
Honda Civic (2001 - 2005)
Jun 15, 2009 07:15 PM
hondamike89
Feb 28, 2009 01:40 PM
