Blower motor doesn't run
Old Oct 18, 2010 | 08:17 AM
slobalt05's Avatar
Default Blower motor doesn't run
i have had this problem since the car got painted the heat would turn on fine with the key on but when you start the car it turns off. it is a 1995 civic dx i replaced the blower motor and the blower motor resistor and it is still doin it. anyone have any idea
Old Oct 18, 2010 | 08:20 AM
Former User's Avatar
Default Re: Blower motor doesn't run
You are talking about the blower not the heat, right?
Old Oct 18, 2010 | 11:48 AM
slobalt05's Avatar
yea im talkin bout the blower it will turn on fine with the key on but when u start the car it wont turn on and i have the controls on like 1,2,3,4
Old Oct 18, 2010 | 12:44 PM
You may have an ignition switch problem. Does anything else electrical not work after the engine is started?
Old Oct 18, 2010 | 04:31 PM
slobalt05's Avatar
no and it started to work today but its not everytime and how hard is an ignition switch to replace
Old Oct 18, 2010 | 05:04 PM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/ignitionswitch.html
Old Oct 18, 2010 | 05:13 PM
Does the rear window defogger also stop working? If so, the ignition switch is probably bad.
Here's how to test it:
Old Oct 19, 2010 | 10:14 PM
AnthonyEKPRJ's Avatar
could this be the reason my 96hx civic's air and heater wont blow any air at all?? the fuse keeps blowing
Old Oct 20, 2010 | 05:41 AM
What fuse?
If unplugging the blower motor prevents the fuse from blowing, then the motor likely is bad due to a short inside.
Old Nov 10, 2010 | 07:54 AM
slobalt05's Avatar
well this weekend i replaced the ignition switch and its still doin the same thing as it was before i am running out of ideas
Old Nov 10, 2010 | 09:24 AM
You must test before replacing parts. Your strategy will get expensive fast.
cadougherty_67
Jan 29, 2016 11:29 AM
cadougherty_67
Jan 27, 2016 03:24 PM
badfish2282
May 15, 2009 08:45 PM
95greenlude
Dec 24, 2007 07:01 AM
b00sted4dr
Jul 31, 2006 05:14 PM
