Need new block for d16y8: What blocks are compatible?
so I have a 96 civic ex coupe with a D16y8 motor. The motor shot out on me,now I want to buy a block but I was wondering if i can't find the same block,what other block can I use wit out having to do any mods to it.
the only complete longblock you can buy which won't require any mods to make work is the exact one that's already in there. a z6 will require rewiring of the dizzy (since the y8 dizzy won't bolt to head properly), and it lacks both a ckf and knock sensor.
if i were you, i'd consider doing what i did. when i got my 96 the y8 already had a hole punched through the front of it. so i converted to obd1 and dropped in a z6.
$300 for the engine, $100 for ecu, $40 for jumper harness, $110 for new clutch and flywheel resurface, and $75 for cap, rotor button, plugs, wires, oil and filter. so a little over $600 is what it cost me.
Any "D" series block will work.
yes any d-series will work, but he said without having to do any mods to it.
y7 is of course non-vtec so with the stock y8 ecu he will be throwing vtec related codes.
He'll need to remove the oil jet from the Y7 block, op here:
http://www.jdmuniverse.com/forums/view_minime.html
spoonfedcrx
Jul 18, 2011 01:53 PM
Snowman3645
Sep 6, 2009 10:34 AM
cevinklark
Dec 31, 2005 07:32 AM
