Play in the shifter? Is this normal?
Old Oct 13, 2010 | 03:24 PM
sk8shorty012's Avatar
Default Play in the shifter? Is this normal?
Car: 1999 Civic EX w/B16A3.
I've got GSR shift linkage, with a GSR shifter. When I went to change out something under the car today I noticed that the "joint" that fits inside the shifter is the piece actually touching the ends of the shift linkage. In other words, the shifter itself can slide 1/4" to each side on that joint before hitting the end of the linkage. It seems like this would cause play or is this how it's designed?
Old Oct 13, 2010 | 03:41 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Play in the shifter? Is this normal?
It shouldn't play like that. There should be a bushing and spacers there.
Old Oct 13, 2010 | 05:33 PM
thanks I was missing the thrust washers
skratchyy93eg
Transmission & Drivetrain
Mar 4, 2016 05:37 AM
91grape
13
Oct 24, 2012 06:41 PM
twentyhurtz
Jun 19, 2009 03:53 PM
dr_latino999
22
Jan 15, 2007 04:14 AM
Sketch_hs
21
Mar 31, 2004 12:51 PM
