95 civic hatch - Rubbing in the rear
Old Oct 13, 2010 | 11:45 AM
motrayEG6's Avatar
Default 95 civic hatch - Rubbing in the rear
i got a 95 civic hatch i have been rubbing only on my driverside rear around strong right hand corners and bumps when im at speed, i just put in energy trailing arm bushings yesterday along with new lower control arms, i have H&Rs standard strut with tein springs any other questions please ask and any help is greatly appreciated thanks
Old Oct 13, 2010 | 12:20 PM
tlarimer's Avatar
Default Re: Rubbing in the rear
What size rims and tires? What is the offset of your rims? What is the lowered height with your springs/struts? Do you have any sway bars, front and/or rear?
Old Oct 13, 2010 | 03:11 PM
motrayEG6's Avatar
Default Re: 95 civic hatch - Rubbing in the rear
205/55 15, GSR blades dont know offset, couldnt tell u how much it dropped i can put one finger flat with my tires, stock sway bars
Old Oct 13, 2010 | 03:50 PM
thecruzs2007@yahoo.com's Avatar
roll your fenders
Old Oct 13, 2010 | 04:13 PM
tlarimer's Avatar
EG hatchbacks did not come with rear sway bars and only a few trims came with front sway bar. 205/55 15 are wider and taller than recommended oe equivalent tires, thats part of why you are rubbing when cornering.
Old Oct 13, 2010 | 07:04 PM
motrayEG6's Avatar
yea im looking at 195/50 for my next tire, but i never rubbed in my old hatch with the same rims and tires. ill add sway bar to my list of parts to buy soon lol, i was thinking it was a blown shock maybe?
Old Oct 13, 2010 | 07:13 PM
eg6stroker's Avatar
go with 205/50
Old Oct 14, 2010 | 01:29 AM
znoj's Avatar
hi guys im new here.. I just want to ask if a PH12 or D13 transmission will fit in
D15b engine.. have an engine d15b vtec but no transmission on it, as of now I have a PH12 or a D13 tranny available. sorry this is a wrong post but i cannot post yet since I am new
Old Oct 14, 2010 | 01:34 AM
Dave.HR's Avatar
U're running on too large tyres, change them to 195x50x15 and then no rubbing will occur. Also check your wheel offset, it shouldn't be lesser then ET38 if the wheels are 7 inches wide.
Old Oct 14, 2010 | 01:40 AM
Dave.HR's Avatar
It will fit. It's oftenly swapped because D13 has a great and short transmission.
Old Oct 14, 2010 | 06:09 AM
motrayEG6's Avatar
thanks for all the help and znoj u are a ratard
motrayEG6
Oct 21, 2010 07:22 PM
Lissav
Nov 8, 2005 05:29 PM
95dxhatch
Aug 5, 2004 09:38 AM
kay_animation
Oct 15, 2003 05:25 PM
jonnybravo
Feb 5, 2002 10:51 AM
