If you had an EG + Tein HA, what would...
...you do?
Well i have a '95 harvard blue EH2 CX, with ITR Tein HA front and back, with ITR LCAs in the back.
This is my daily driven car and i'd like to get the BEST BANG FOR THE BUCK turning ability. My question is what tires to run, and what rear sway bar to use for rear to balance out the car so that i can push the limits?
I have Integra LS mesh wheels which are 15" x 6" (i think)...
What are good tires? (Not azenis, had them and rubbed too much). Tire size should be 195/50/15.
As far as the sway bar, should i run a GSR rear sway bar, or ITR with a beaks kit. Keeping in mind that I don't want my rear end to come out on every corner.
Re: If you had an EG + Tein HA, what would... (Alexandre!)
Before i say anything, have you ever had a bigger sway bar in your car? How do you know that your *** is going to slide with say maybe a 22mm? Im runnin 24mm up front and 22 in back with that subframe brace. With the rear, it makes it feel more rigid obviously and also i noticed it has better turning response. Something like a 26mm is most likely way to big for the setup your running. The 22 isnt subtle but its also not extreme.
Another thing, do you think people with type r's and HA's take off their sway bar and put a smaller one on? I think after you do it youll see what im talking about.
Re: If you had an EG + Tein HA, what would... (delLudeVTEC)
As it sits right now, my car has too much oversteer and ultimately i'd want to minimize it.
I will not be running a sway bar up front (my car doesn't have the LCAs or subframe brackets (too much trouble).
If i was to just run my Teins, what sway bar should i use in the back?
VeilSide_Mas
Suspension & Brakes
04-24-2007 12:13 PM
HybridIntegra
20
11-16-2004 07:38 PM
