What all do I need for a b16 swap into a 99 civic?
Old Oct 12, 2010 | 12:51 PM
Si-rdc2's Avatar
Icon2 What all do I need for a b16 swap into a 99 civic?
what do i all need for this swap in a 99 civic ex
parts i have
motor
ecu
motor mounts
dc shift linkage
dc tranny
clutch flywheel
axles
anything else?
Old Oct 12, 2010 | 06:28 PM
Hondatherdm's Avatar
Default Re: What all do I need for a b16 swap into a 99 civic?
if you gonna use ex engine harness then you might be set to go
Old Oct 12, 2010 | 07:19 PM
TwoFacedCustoms's Avatar
T bracket from an SI. Conversion harness for obd1 probably depending on which ecu you're using.
Old Oct 12, 2010 | 11:07 PM
Si-rdc2's Avatar
I got the obd2 Si Ecu the motor is out of a 99 Si but it is just the motor
Old Oct 13, 2010 | 01:29 AM
HondaPartsHero's Avatar
Technical Hero
You'll need to extend the primary O2 sensor to near the front of the cat at the end of the exhaust manifold header section
Old Oct 13, 2010 | 02:14 PM
Si-rdc2's Avatar
so i guess the wire for the o2 is to short what about the fuel rail and injectors i was going to use the one from the single cam
Old Oct 13, 2010 | 03:10 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The EM1 shift linkage has a bend to clear the O2 sensor in the cat. If you're planning on running that sensor, you need the EM1's stabilizer linkage (the part that doesn't move). I found this out while trying to install a JDM ITR linkage on my EM1. The EM1 has the same cat/O2 sensor orientation as the EX.
You can't use the single cam fuel rail or injectors either. Use the EM1 rail and OBD1/OBD2 B series injectors depending on your ECU setup.
Old Oct 13, 2010 | 04:34 PM
94EG8's Avatar
Seagull Management
You can use D-series injectors depending on what they came from. D15B7, D16Z6, D16Y8 and all B-series are 240cc. most of the other D-series injectors are 180cc Really doesn't matter if they're OBD1 or OBD2 as far as the ECU is concerned, its just easier to get ones that plug into the OBD2 clips.
Old Nov 5, 2010 | 11:05 AM
jimmy janeiro's Avatar
Icon2 Re: What all do I need for a b16 swap into a 99 civic?
Would a B16 swap into my 1995 civic dx be a costly swap or if cost is a concern are there better choices? Thanks
Old Nov 5, 2010 | 01:05 PM
Technical Hero
Unless you are in love with VTEC, a lot of people do the B20Z with a DOHC VTEC transmission due to the gearing.
Old Nov 6, 2010 | 11:49 AM
Thanks for your input. Helpful information.
Old Nov 9, 2010 | 10:59 AM
Si-rdc2's Avatar
I got to smog and I live in Cali no good here
N1YDP
15
Feb 22, 2015 12:12 PM
1SikEagle
10
Aug 23, 2009 01:08 PM
marksae
15
Sep 8, 2007 05:39 PM
killacam661
Jul 27, 2007 06:50 PM
994door
Apr 30, 2007 02:57 PM
