What all do I need for a b16 swap into a 99 civic?
what do i all need for this swap in a 99 civic ex
parts i have
motor
ecu
motor mounts
dc shift linkage
dc tranny
clutch flywheel
axles
anything else?
parts i have
motor
ecu
motor mounts
dc shift linkage
dc tranny
clutch flywheel
axles
anything else?
Re: What all do I need for a b16 swap into a 99 civic?
I got the obd2 Si Ecu the motor is out of a 99 Si but it is just the motor
so i guess the wire for the o2 is to short what about the fuel rail and injectors i was going to use the one from the single cam
Cool Cool Island Breezes. BOY-EE
The EM1 shift linkage has a bend to clear the O2 sensor in the cat. If you're planning on running that sensor, you need the EM1's stabilizer linkage (the part that doesn't move). I found this out while trying to install a JDM ITR linkage on my EM1. The EM1 has the same cat/O2 sensor orientation as the EX.
You can't use the single cam fuel rail or injectors either. Use the EM1 rail and OBD1/OBD2 B series injectors depending on your ECU setup.
Seagull Management
You can use D-series injectors depending on what they came from. D15B7, D16Z6, D16Y8 and all B-series are 240cc. most of the other D-series injectors are 180cc Really doesn't matter if they're OBD1 or OBD2 as far as the ECU is concerned, its just easier to get ones that plug into the OBD2 clips.
N1YDP
15
02-22-2015 12:12 PM
1SikEagle
10
08-23-2009 01:08 PM
marksae
15
09-08-2007 05:39 PM
