D16Y8 broken valve cover bolt - What size/type is the bolt?
Old Oct 11, 2010 | 07:14 AM
titi_vtec's Avatar
Icon4 D16Y8 broken valve cover bolt - What size/type is the bolt?
ok i need to know what size are those bolt and what type of nuts they need thanks
Old Oct 11, 2010 | 07:18 AM
titi_vtec's Avatar
Default Re: V.cover broken bolt help ASAP
ohh my engine is a D16Y8
Old Oct 11, 2010 | 07:26 AM
paopao's Avatar
Get it from Honda.
Old Oct 11, 2010 | 07:30 AM
SLURS's Avatar
local junkyard would help too!
Old Oct 11, 2010 | 07:44 AM
SIM Racing's Avatar
Get it from honda. its expensive but you are guaranteed it will work. they are from 7-15 bucks
Old Oct 11, 2010 | 09:44 AM
titi_vtec's Avatar
yeah but the thing is that i dont want stock bolt i want one with thread in both side one for the head and then put V.cover and nuts over this one to the other side of the bolt, you feel me
Old Oct 11, 2010 | 10:03 AM
87 SiviK Si's Avatar
Take VC bolt to a nut & bolt store, tell em you need all thread or a stud with that pitch/TPI at "x" length.
Old Oct 11, 2010 | 10:09 AM
titi_vtec's Avatar
that sound nice but here were i live isnot any boltstore and i dont know if in home-deport they sell this things
Old Oct 11, 2010 | 10:12 AM
Eran's Avatar
HT White Ops
If you have a Y8, you can't use anything that's not stock. It's a special bolt with a gasket on it. You could make something ghetto that would work, but chances of them having a bolt that long that has that fine of a thread pitch (M6x10 IIRC) is close to zero. You'd have to use threadstock, an acorn nut, gasket, and a washer. Ghetto.
You broke it because you over torqued it, not because it's a weak bolt. They're only supposed to be torqued down like 12lb/ft. That's barely a quarter turn past hand tight.
Old Oct 11, 2010 | 10:18 AM
titi_vtec's Avatar
yeahh thats what happened to me, but i will put the little gasket that it need on top but i want make somenthing nice like i wrote before, so you thing that it is impossible to put other bolt there
Old Oct 11, 2010 | 10:20 AM
Eran's Avatar
HT White Ops
I think it's near impossible to find a proper bolt. If you want them to look nice, get all brand new stock ones. They'll have that perfect army green Honda bolt finish.
Old Oct 11, 2010 | 10:26 AM
titi_vtec's Avatar
yeah but the thing also is that my head loss the thread at the beging its has at the end so i need to put bolt to the end of find one a little bit more large
FTNW
10
Sep 23, 2012 07:31 PM
yeedub
Jan 16, 2012 06:02 AM
itr1244
Aug 5, 2007 11:19 PM
LoseRPunKx182
Aug 8, 2005 12:49 PM
thrty8street
34
Jun 28, 2004 07:06 AM
