time for a new clutch?
Old Sep 19, 2002 | 06:03 PM
Dorikamu's Avatar
Default time for a new clutch?
I hear this noise when I step on the clutch... sounds like some old door opening..
is this a sign of needing a new clutch?
Old Sep 19, 2002 | 06:36 PM
hoya_10fintec's Avatar
Default Re: time for a new clutch? (chusai)
...when u step ON the pedal or letting the pedal out(disengaging or engaging??)? where exactly do u here the noise from?
Old Sep 19, 2002 | 06:41 PM
Dorikamu's Avatar
Default Re: time for a new clutch? (hoya_10fintec)
there is noise for pressing and releasing... like a old door opening if you know what I mean.. almost like a low "sweaking" sound..
Old Sep 19, 2002 | 07:04 PM
hmm... it sounds like it's got nothing to do with clutch or tranny... when clutch is worn out, in my case, the whole car vibrated bad when letting out the pedal and quite a bit of play(from the pedal all the way down to engaging...) in some cases, clutch slipping...
try to lubricate all the joints and all the moving parts where the clutch pedal is... and see what happens...
--my clutch pedal used to make that kind of similar noise a while ago... i just lubricated... and it worked...
when was the last time u replaced ur clutch? how many miles did u put on since new?
[Modified by hoya_10fintec, 4:06 AM 9/20/2002]
Old Sep 20, 2002 | 03:50 AM
Dorikamu's Avatar
I got it from the swap, so I had no idea when was the clutch replaced...
Old Sep 20, 2002 | 07:58 PM
3rdGteg's Avatar
Put some grease on the little ball joints in the rubber boot where the clutch slave cylinder goes into; it worked for me.
Old Sep 20, 2002 | 08:02 PM
IM ALL BOB's Avatar
Default Re: time for a new clutch? (3rdGteg)
possible bad throwout bearing.. simply replace when u get a new clutch.. could also be what the guy said above..just get a new clutch =P
LandeZak
Sep 9, 2013 10:38 PM
siboii08
Honda Civic (2006 - 2015)
Mar 27, 2008 08:35 AM
megaman096
Nov 8, 2004 11:26 AM
killerslp
Jan 25, 2004 05:35 PM
