Budget h2b kit
the evolution kit has the motor sit lower and tilts back more than the QSD. It also moves the swap to the passenger side about an inch. You also get a different shift fork for the transmission rather than using the oem one. You also need the evolution mounts, can't use any b-series mounts. The QSD kit does not move the transmission like the EVO kit. You can use any b-series motor mounts. Engine does stick out more. Better ground clearance. I've been using the QSD kit for about 4 years now. No problems so far.
i heard the east coast guys are just using the adapter plate just to mock up the tranny and see where the tranny bolt will go, after they figure where the tranny bolt goes they'll drill and tap the block so they tranny bolts to the block and not the adapter plate.
I figure I'd give it a shot. I got a f22b1 and H23A cheap:
http://www.d-series.org/forums/showc...ld-thread.html
evogrl
May 23, 2007 11:00 AM
J1A1H
Jan 8, 2006 11:00 AM
untitled
Dec 22, 2004 07:26 AM
