ITR IM VS. GJ Edelbrock or Skunk 2
Old Sep 19, 2002 | 01:34 PM
SqueezinEF's Avatar
Default ITR IM VS. GJ Edelbrock or Skunk 2
Comments....
Is there much of a difference? I have a 1st gen B16 and want to replace the IM. Which is the best bang for the buck?
Any advise appreciated.
Old Sep 19, 2002 | 01:57 PM
spettinger's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (SqueezinEF)
i have been in cars with skunk2's and ITR manifolds, decent improvement over stock. i think if you can get the JG manifold for not much over the skunk2 then it would be worth it. your valvetrain better be able to spin really high to take advantage of the high end gains.
Old Sep 19, 2002 | 02:19 PM
Brandon Chun's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (wreckedhatch)
From what I understand the JG IM is supposed to be the best for boosted applications, NA I have no idea, if it is the best, but it cost a bit more than the other two you mentioned. I had the Skunk 2 Im on my B16A Rex for a bit, it was pretty nice..I'd say Skunk2
Old Sep 19, 2002 | 02:43 PM
allmotorls95's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (Brandon Chun)
jg is way better the wholes don't even properly match up correctly, personally i think skunk sucks and is a waste of money..go jg..
Old Sep 19, 2002 | 03:43 PM
SqueezinEF's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (allmotorls95)
Any comments on the ITR IM?
Old Sep 19, 2002 | 05:00 PM
xtrafastcivic's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (C5_ALLMOTOR)
the inside of the Im and intake side of the head are suppose to be rough so the air and fuel mix better...
Old Sep 19, 2002 | 11:20 PM
riceboy's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (XtraFastCRX)
use the ITR intake manifold for the N/A applications. To fully exploit the power with intake monifold upgrades on a normally aspirated car, you'll need to invest in cam gears and an hour of dyno time.
Old Sep 19, 2002 | 11:50 PM
AussieK24's Avatar
How does the fuel and air mix in an IM??? Fuel aint injected until the last inch of the manifold...
I'd say skunk or ITR, whichever you can get cheaper.....Leave the JG for the racecars/turbos.
Old Sep 20, 2002 | 12:00 AM
riceboy's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (b16a4me)
b16a4me , fuel is mixed from the velocity of the intake charge and the dispertion pattern of the injector, there are alot of many other contributing factors, but those are two of them to give you an idea. With a different intake manifold you are hoping to increase swirl for better atomization of the intake air/fuel mixture as well as hoping for a more direct path into the ports for "better" or "more" air flow, but this just scratches the surface.
Old Sep 20, 2002 | 12:09 AM
AussieK24's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (riceboy)
I think that sand cast vs polished would make sweet bugger all difference to "swirl" or fuel atomization. On an old school carburettor manifold sand cast may assist fuel atomization and prevent fuel from "dropping" out of the airflow but with EFI I have my doubts
This is just my opinion and I am far from a "tech god"
Old Sep 20, 2002 | 03:57 AM
Charlie Moua's Avatar
due check out the FI form.... there was a huge group buy on the JG manifold and afew people who got them said that they dyno it and lost about 10hp throughout the entire powerband........ now some if them want their money back. I wounld get that manifold. Just stick with stock and extrude hone it.
Old Sep 20, 2002 | 07:49 AM
SqueezinEF's Avatar
Default Re: ITR IM VS. GJ Edelbrock or Skunk 2 (Charlie)
thanks all for the replies. I think I'll go with ITR stock.
VinceVTEC
Feb 17, 2004 05:45 AM
Sassafrass
14
Sep 9, 2003 06:31 PM
soloteg
Dec 1, 2002 06:03 PM
b16powwer
18
Jul 7, 2002 01:02 PM
