Need help with offset
Old Oct 2, 2010 | 07:51 AM
D-NASTYY's Avatar
Default Need help with offset
whats up im new here but i drive a EK coupe and im thinking about trading my rims for some diamond racing rims but they are 13x9 with +12
this will be my first offset wheels so i need to know if they will fit and what problems i will have any info with help thanks
Old Oct 2, 2010 | 07:52 AM
D-NASTYY's Avatar
Default Re: NEED HELP WITH OFFSET!!!!
these are the wheels
http://www.importatlanta.com/forums/...-Racing-Wheels
Old Oct 2, 2010 | 08:01 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Need help with offset
BAD IDEA.
For street and daily driving use, you really really REALLY shouldn't get rims that small in diameter or that wide. There are NO 13" street tires with decent performance; like the ad says, "good luck finding tires". Those 175/50-13 tires currently on them are way too small for your car, and they're also way too narrow for 13x9 rims. A 13x9 rim is too wide for any 13" size your car would use. If it's for track or autocross use, you might be able to find some R compound tires to fit.
Also, since the '97-00 Civic only came with 14" or larger wheels, I don't know if 13" wheels can even clear your brakes.
Your best bet is to stick with 14-16" wheels with the appropriate size tires. In particular, a 15" diameter offers a lot of excellent tires in the 195/55-15 and 205/50-15 sizes you would use, and you can get a nice set of used 15x6 Integra wheels without spending a lot of money. If you buy new wheels, keep the width no wider than 7".
Remember, the best approach is to decide what size and kind of tires you're going to use FIRST, and THEN find out what width wheels will fit. Don't do things backwards and buy wheels, only to find out that they're too wide for any tire size you would use.
Old Oct 2, 2010 | 09:40 AM
D-NASTYY's Avatar
alright thanks for everything man!
swtreaper
Jul 20, 2011 04:57 PM
()()DC2
Sep 24, 2008 12:41 PM
p0tential
10
Mar 28, 2008 09:18 PM
eL
May 19, 2004 11:11 AM
Pele
Aug 4, 2003 09:37 AM
