front wobbles under hard accel or high rpm
Old Oct 2, 2010 | 12:50 AM
DC2many's Avatar
Default front wobbles under hard accel or high rpm
damn i think this is most likely due to running over some MASSIVE multiple potholes... **** at night couldnt see and it was some uncharted *** territory
this **** was bad ground was all chopped when i realized it was too late to slow down
i hope my ****ing wheels arnt bent the bumps were bad enough to make my spec 2 disconnect from the axleback to S pipe
usually over 3k+ under hard accel and 4k+ i occasionally get some bull **** WOBBLES in the front end and some LUMPY driving
any ideas? thanks
Old Oct 2, 2010 | 09:45 AM
SF_Du ma may's Avatar
Default Re: front wobbles under hard accel or high rpm
i think its your wheel bearings...check to see if they are tight!!! if not u may have warped your bearings
Old Oct 2, 2010 | 09:51 AM
Drive 4 fun's Avatar
"warped your bearings" ???
Jack the corners and spin the wheels by hand. That will spot some bends and out of round wheels. Best to have spin balance which will check balance and will clearly see problems with tires and wheels. If not that, you will need to check suspension components, bushings, and steering for a start.
Old Oct 2, 2010 | 06:44 PM
DC2many's Avatar
^still couldn't tell from spinning the wheels.
**** **** i'll see what i can do on monday and go to a shop and get some quotes on **** too
Rednas
13
Nov 13, 2011 07:37 AM
duwa
Oct 26, 2011 08:19 AM
JDM_SOHC
Mar 24, 2006 03:49 PM
NAmodified
Mar 17, 2006 11:51 PM
jdmstreethatch
Jan 11, 2004 04:28 PM
