Honda S2000 Honda S2000
transmission grinding, rattling, ringing
Old Oct 1, 2010 | 11:10 AM
wheelspk's Avatar
Default transmission grinding, rattling, ringing
hello people,
well since i bought my 03 s2000 AP1, i noticed there were a lot of tranny or atleast coming form that area noises,
when im just cursing in low revs 1,2 or 3 there is a noticeable loud rattle or grinding when i have a constant foot on the gas pedal. even when i let go of the gas there is grinding and rattle.
at abt 7000 rpm there is more rattle and ringing noise.
here are the video,
http://www.youtube.com/watch?v=hIA6ynbMqzw
http://www.youtube.com/watch?v=xZb5m4_Fqkc
there is also a noticeable constant noise when i have the car in neutral gear and foot of the clutch pedal, but as soon as i press on to the clutch pedal the noise goes away.
here is video,
http://www.youtube.com/watch?v=dVjlbCn7rt8
does any body have any idea what these grinding noises are? do i need to change my flywheel and clutch?
thanks and regards
Old Oct 2, 2010 | 08:11 AM
wheelspk's Avatar
Default Re: transmission grinding, rattling, ringing
bump.......
Old Oct 2, 2010 | 08:16 AM
Targa250R's Avatar
be professional
Have you checked the transmission fluid level?
Old Oct 2, 2010 | 08:43 AM
wheelspk's Avatar
yes changed it few days ago....
Targa250R's Avatar
be professional
What fluid did you use?
Old Oct 2, 2010 | 09:27 AM
wheelspk's Avatar
it was a import brand we have here by the name ZIC 75W/85.....
Old Oct 2, 2010 | 09:31 AM
wheelspk's Avatar
which grade is best for our gear box?
Old Oct 2, 2010 | 06:36 PM
Robert O's Avatar
The tranny doesn't use 75/85 gear oil. You need to drain that crap out of there asap. You need to use Honda manual transmission oil or GM synchromesh.Both are a 10W30 range lubricant. Always read the manual or do some research before changing lubricants. It can save thousands of bucks in damage. You'll want to flush the system out with the proper lubricant.A quart or so flush should help.Then top it off with the drain plug installed until it weeps out of the top hole.Make sure vehicle is on level plane when topping off to insure proper fill level.
Old Oct 3, 2010 | 02:12 AM
wheelspk's Avatar
is Mobil 1 or liqui-moly any good? coz these are the only ones available here
im also thinking abt using liqui- moli gear protection kit
this one:
http://www.youtube.com/watch?v=33DZXIeoeRk
Old Oct 3, 2010 | 10:51 AM
wheelspk's Avatar
bump
Old Oct 3, 2010 | 12:36 PM
909 eg kid's Avatar
rhd s200 sick. change tranny. its not da clutch
Old Oct 3, 2010 | 01:04 PM
wheelspk's Avatar
aaaaaaaaaaaaaaaaaaaa........i don't think so
MudBggn
May 5, 2022 04:44 AM
Old_Liver
Honda Fit
Jun 21, 2017 01:02 AM
J-Willz
Honda Civic (2001 - 2005)
Jul 24, 2007 08:24 PM
MoogieBoogie
Sep 16, 2004 10:04 PM
LFE142
Mar 25, 2002 03:04 PM
