Test VSS 1996 Civic DX Automatic
Old Sep 27, 2010 | 09:12 PM
steve56's Avatar
Default Test VSS 1996 Civic DX Automatic
I have no speedometer or odometer reading on my speedometer guage . Somtimes the speedometer needle jumps between 0 and 20 mph. The OBD 2 meter shows code for problem with VSS. How do I test VSS to find problem?
Old Sep 27, 2010 | 09:17 PM
Former User's Avatar
Default Re: Test VSS 1996 Civic DX Automatic
Have you checked whether fuse 15 is blown?
Old Sep 27, 2010 | 09:41 PM
steve56's Avatar
Fuse is good.
Old Sep 27, 2010 | 09:54 PM
The VSS has three wires - power, ground, and signal. Does the Blk/Yel power wire have voltage with the key in ON(II), and does the Blk ground wire have continuity to body ground?
Does the Blk/Wht signal wire have an open between the VSS and ECU or a short in any of its branches (ECU, speedo, cruise control)?
Old Sep 27, 2010 | 09:58 PM
steve56's Avatar
Thanks I will check that out
Old Sep 27, 2010 | 10:00 PM
There are additional tests, but those are the place to start.
Old Oct 26, 2012 | 05:18 AM
jdmem205's Avatar
Ilu thread but I figure it would be better then to start a new one. What should the voltage be at?
joeydd3
Jun 16, 2018 04:30 PM
Vtec Civic 93
10
Sep 2, 2010 08:52 PM
2000CivicEK
11
Jun 18, 2009 05:50 PM
atownludeh22a
Jan 11, 2009 01:32 PM
chewabacha
Feb 22, 2005 09:57 AM
