Transmission & Drivetrain Gearboxes, Differentials, Clutches
All B-series differentials the same
Old Sep 22, 2010 | 02:40 PM
simike's Avatar
Icon2 All B-series differentials the same
I need to buy a B-series diff and want to know what will fit in a S4C B16 trans. Will a LS, GSR or B16 all fit? Is it just the ring gear that is needed? I have read that the ring gear bolt patterns vary, so I wouldn't be able use my OEM B16 ring gear. Also, I have heard that any B-series diff will fit as along as it is a complete diff and ring gear assembly? What about a cable diff in a hydro trans? Thanks for the help!
Old Sep 22, 2010 | 03:19 PM
Honda Bull's Avatar
Default Re: All B-series differentials the same
92-93 GSR, 92-00 B16, and 92-01 LS use the same differential. You can use any of them unless it's a factory viscous LSD which uses a different bolt pattern, so you'd need the ring gear / countershaft as well.
Old Sep 22, 2010 | 04:29 PM
simike's Avatar
Thanks for the info. I know you know your transmissions, but can anyone else confirm?
Old Sep 22, 2010 | 04:37 PM
hondadriver's Avatar
What Honda Bull said is correct. If you want a bolt in factory diff for you b16, buy a diff from one of the cars listed by Honda Bull.
The 96+ gsr and type r diffs have a differen bolt pattern, which means you'll need a new ring gear, counter shaft, etc,etc..
I installed a jdm 4.785 final drive into my jdm 2nd gen b16a tranny. I didnt have the extra money for a type r diff, so i bought a 98 gsr open diff on ebay for $30.
Old Sep 22, 2010 | 04:54 PM
e46civic's Avatar
Type R Torsen will fit with minimal grinding of the case interior and a GSR ring gear. Also needs B16 bearings pressed on.
Old Sep 22, 2010 | 05:04 PM
simike's Avatar
Thank you all for the feedback.
Is there a way to identify the diff's so I don't have to take someones word only to find out they lied or didn't know what they had? Markings? Can I measure something? Other?
Old Sep 23, 2010 | 01:48 PM
simike's Avatar
Any ideas on how to ID a diff?
Old Sep 23, 2010 | 06:07 PM
David @ Synchrotech's Avatar
OEM B16/LS diff will be stamped "PS1" and the GSR diff will be stamped "P80"
Old Sep 23, 2010 | 06:48 PM
simike's Avatar
Awesome, that's exactly what I needed to know!
BlueTeg
Apr 2, 2014 01:00 AM
ashb82
Aug 15, 2011 02:28 PM
sj-performance
Nov 9, 2009 02:35 PM
fastfiveo2
15
Dec 25, 2007 03:32 PM
DaveF
Sep 22, 2003 08:53 PM
