check engine light....
Very rarely is the CMP the actual problem. It is possible that your vehicle has experienced timing chain stretch or misalignment. The CMP is very easy to change. How many miles are on your vehicle and how long have you owned it? Do you know of any prior work/ issues that might have damaged the CMP? BTW what codes are present in you PCM?
What is BTW and PCM? I understand that the camshaft sensor plays an important role to have a regular idle, and it regulates some other things as well.
I had my buddy run diagnostics and it's the only thing that came up.
what are the 2? I don't know the technical name for it. but it read camshaft position sensor failed or incomplete.
Do you have DTC P0341? If not then what?
If your car is 03 4 cylinder then your car definitley has a timing chain and not a timing belt.
CMP= Camshaft Position sensor
BTW=by the way. PCM Powertrain Control Module aka computer.
There are 2 CMPs THey are named CMP A and CMP B.
What is the code?
What is the code?
What is the code?
What is the code?
civicvitaminwat
Honda Civic (2006 - 2015)
Apr 9, 2016 12:03 PM
streetracerof06
Dec 5, 2005 07:52 AM
