what to use to block the pcv on the block?
Old Sep 18, 2002 | 07:28 PM
Ri5e's Avatar
Default what to use to block the pcv on the block?
I got a b18a. Sleeving it. Noticed that there is a hole on the back of the block that is about 1 1/2 inch in diameter. I think its the PCV thingy. However I have a B18B (The 96+) head that uses the PCV on the VALVE cover instead.
What can I use to block this hole shut?
Old Sep 18, 2002 | 08:13 PM
earl's Avatar
Default Re: what to use to block the pcv on the block? (4 Stroke)
Why not use both?
Old Sep 18, 2002 | 09:20 PM
tonyxcom's Avatar
Default Re: what to use to block the pcv on the block? (earl)
Use both.
Positive crank case preasure is bad.
Old Sep 18, 2002 | 11:35 PM
Ri5e's Avatar
What does this oil accumulator thing look like ? And how much does it cost?
My B18A is missing it.
Old Sep 19, 2002 | 04:00 AM
BROOD's Avatar
You would want to use both to ensure minimal crankcase pressure. I would suggest using both, buying a breather kit (ENDYN or IB), or piecing together your own breather kit.
Stock (The breather chamber is the box part of assembly #2)
Aftermarket kit (ex. ENDYN) I'm not sure what the IB kit looks like but contact them for info.
But........If you opt to plug that hole though you can easily find a block-off plug or "freeze plug" that will fit the hole diameter. The plug is a bit larger in diameter. Coat the plug edges in Hondabond and drive the pluf into the breather hole.
[Modified by SLPR, 5:04 AM 9/19/2002]
Jamison
Jul 15, 2011 11:20 AM
b16vtecsol
Dec 26, 2004 04:41 AM
SOUNDEFFECTS
Nov 26, 2002 07:23 AM
highbrid
Oct 14, 2002 08:33 AM
