need help eliminating srs light with personal wheel
Old Sep 18, 2010 | 05:03 PM
bluelsvtecda9's Avatar
Default need help eliminating srs light with personal wheel
i have a personal wheel that i am going to install in my 00 civic dx. Id like to know how to get rid of srs light and wire the horn. If anybody can help i would appreciate it. Thanks in advance......
Old Sep 18, 2010 | 05:07 PM
Jas9848's Avatar
Default Re: need help eliminating srs light with personal wheel
You are gonna have to unplug the connector for the SRS unit in the back of the cluster. I think it's the 2-pin, yellow plug. For the horn, get a tab piece off a CRX or DA Integra and wire it up, some people use pen clips also. There are a few threads about it on here.
EJeff8's Avatar
Should be a yellow jumper plug sitting by the fuse box. Jump the pins with a wire and you have to do a certain key turning sequence.
Old Sep 18, 2010 | 05:27 PM
redline75's Avatar
this only works to reset the srs system to remove a light but it will pop right back on once the system doesn't see the airbag plugged in for the steering wheel what i did on my civic was unplugged the srs harness from the rear of the cluster there for it never receives the signal to turn on the light
Old Sep 18, 2010 | 09:23 PM
TwoFacedCustoms's Avatar
There's a write up on it somewhere its in my favorites on my comp ill post in the morning im on my phone now....it shows the exact resistor to use as a jumper for the srs plug so your light stays off and your passenger bag still works.
Old Sep 18, 2010 | 10:17 PM
D16SiHatch's Avatar
indeed there is a writeup :p
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-bypass-srs-aftermarket-wheel-2398113/
ITR010342
May 8, 2009 08:27 AM
DeDonDeRosa
Oct 15, 2007 05:29 PM
94allmotor
Sep 4, 2007 01:52 PM
RineRacing
20
Jan 24, 2003 06:55 AM
servion
Jan 14, 2002 01:54 PM
