I painted over the spark plug seals in my valve cover
ok so today i painted my vc and I got a new main seal but i didnt take the spark plug seals out i painted right over them it runs good and doesn't leak but is that bad i did that?
are you talking about the orings that seal the spark holes? I would just check em every once and awhile. if you pull the plug wire and there oil on it at all they arent sealing. but I cant imagine that it would matter that much.
Well as long as its not leaking it doesnt really matter. But when you take off the valve cover, its going to break the paint lol
It will be fine, and there is no reason it should leak. It will probably look kind of cheap as in it was just over sprayed.
Why wouldn't you spend 5 mins and just removed the valve cover plugs, and tape off a couple spots? I just did one about a month ago when doing a head gasket job, so easy!
Ok thanks a lot guys i don't have any problems but now it is leaking just a little on the front right side (looking at it) so what should i do about that?
my red y8 cover
and my ls covers.
they've also been white, black, yellow, candy apple red, and metallic green lol.
themorphious
Jun 3, 2006 12:14 PM
