d16z6 turbo build
d16z6 turbo build
hey guys just sharing my project for this march 2010. Bought h beam rod with vitara piston standard. arp head stud, cometic gasket .40 mm, and turbo kit coming in soon. Will be running with a ebay turbo t3/t4 turbo 50 trim and 63 ar. with fuel pump walbro and 650 inj cc. hoping on breaking high 200s.
post pic tomorrow.
post pic tomorrow.
Re: d16z6 turbo build
the block.
http://i7.photobucket.com/albums/y27...rLd/piston.jpg
piston rings seems to be good thought it would of been bad with my old t25 turbo kit.
new rod and piston two is laying somewhere lol
well atleast you have it out now, a flat rate engine rebuild isnt going to cut it for something like this. and i hope you plan on taking some stuff to the machine shop even if you aren't getting anything balanced atleast have the cylinders cleaned up.
BTW, you should probably either employ the use of a tripod, or atleast a camera man without uncontrollable seizures.
i hear ya, i would just hate to see someone put forth so much effort into something and have it all go to **** to cut a few corners. If it's something like this and you don't have the money, save. If you don't have the money now you definitely won't when you have to do it the second time.
have you even done something simulair to this
lemme know if you need and info about building it.
i have done this build several times. i hated notching the block next time i do it i am just boring the block much easier and you don't have to worry about the block getting weak because you gotta take off so much metal when notching it. and you should get well over 200 whp i made 260 whp on 11lbs with built bottom and intake mani. as long as you got a good tuner you should see good numbers and be able to have it last at least a year but possibly even longer depends on how you treat it.
i've never done a D, i've always been a B kinda guy, so when it comes to notching your block and what not i can't help ya. Your power goal seems pretty reasonable and it should be a very fun car.
i love b series, just want to do a d series turbo charge in my citie, since i seen lots of b swap in civic and all just wanna do a small project. but hopefully its successful lol.
speaking of cutting corners ... lol
there isa hone tool that you can attach to a drill and hone the cylinders your self, if you didnt have the money to get the block honed by a shop
