civic flood and miss at low rpm
Old Sep 13, 2010 | 02:38 PM
92vtechhatch's Avatar
Icon3 civic flood and miss at low rpm
ok here?s the problem i have my civic hatch when you start it idles ok for MIN THEN IT GOES TO idling up and down and missing and flooding when you pull out it misses and hops and skips till bout 3000 rpm then clears up ive changed plugs fuel filter ..i dunno whats wrong with it need ideas!
Old Sep 13, 2010 | 03:33 PM
delsolproblems's Avatar
Default Re: civic flood and miss at low rpm
Revving idle (bouncing from normal idle to higher RPM) is usually a vacuum leak/ idle set incorrectly. Dying idle (bouncing from at or close to normal idle downward to almost stalling) can come from almost anything else. Bogging when you floor it from a stop is usually weak ignition. Hope this helps find the problem.
Old Sep 13, 2010 | 04:13 PM
it goes from normal to almost stalling it doesnt bog it cuts in and out bad till 3000 doesnt matter partial throttle or full it does it some days others it dont
Old Sep 13, 2010 | 07:32 PM
If it doesn't bog when you floor it from a stop then the ignition probably isn't the main problem. The most likely causes are compression & timing. Timing's easier to check but the comp sounds more likely.
Old Sep 13, 2010 | 08:15 PM
Former User's Avatar
Have you checked the plug wires, distributor cap, rotor, and ignition timing?
Any CEL codes?
hell0curry
Apr 4, 2012 11:20 PM
ge_itr
Oct 16, 2007 05:12 PM
ITLNstallion818
Jun 18, 2005 02:56 PM
speed junk1e
May 29, 2004 10:49 PM
