B20b-D16 obd-2 ecu- Crank Angle Sensor?
A friend has a b20b, and d16 (non-vtec) harness and ecu(obd-2, 2000). The harness plugs perfectly into everything on the motor, except
the b20 doesn't have a crank angle sensor like the d16. Can this ecu control it without the sensor, or does one need to be added?
Thanks!
Andy
the b20 doesn't have a crank angle sensor like the d16. Can this ecu control it without the sensor, or does one need to be added?Thanks!
Andy
Awesome sounds good. If you email me we can work out the details, andy@ins-brokers.com . The d series non vtec ecu will run the b20b won't it?
Thanks!
Thanks!
