Crank Sensor Problem
Old Oct 4, 2011 | 10:01 PM
nothing_shocking's Avatar
Default Crank Sensor Problem
98 GS, b18b1, stock ecu. I bought an OBD1 ecu for it so I left the crank sensor off (rebuilt the block). My question is, how will it run with no crank sensor on the OBD2 ecu? Timing advanced? Retarded? Be fine?
Old Oct 4, 2011 | 10:26 PM
mouab18c1's Avatar
Default Re: Crank Sensor Problem
The car will run retarded with the sensor not hooked up.
Old Oct 5, 2011 | 12:30 AM
pakn-heat's Avatar
I had a friends of mines honda not even start and trow cel for ditsributor just for it not beng plugged in all they way...looked over everything so many times..
Probly be good just to stay wit obd1 ecu..or put it back in and stay obd2,or for just incase you ever need to use your obd2 ecu
Old Oct 5, 2011 | 01:31 AM
HondaPartsHero's Avatar
Technical Hero
It's not a crank position sensor, its a crank fluctuation sensor. The crank position sensor is in the distributor. The crank fluctuation sensor detects misfires on OBD2 Honda's/Acuras. The OBD1 ECU doesn't look for this. It will run fine.
Old Oct 5, 2011 | 05:54 AM
fcm's Avatar
fcm
Old Fart
Found this... http://www.ff-squad.com/technet/ckftrick.htm 94
Old Oct 5, 2011 | 07:55 AM
Technical Hero
He's using an obd1 ecu he won't have to bypass it, because it doesn't look for it.
Old Oct 5, 2011 | 09:00 AM
mouab18c1's Avatar
Actually his post does not determine which ecu he will be using
Thategguy94
Feb 7, 2015 01:15 PM
akinas-crx
Oct 28, 2011 06:00 PM
GruvyTune
Feb 1, 2010 10:45 AM
TheOwnrOfTheEk9
Mar 7, 2006 06:10 PM
gotjesus
Nov 7, 2003 09:03 PM
