H block hone statement
Old Sep 12, 2010 | 01:50 PM
Nocture's Avatar
Default H block hone statement
Originally Posted by *****
h22a motors have f.r.m sleeves the sleeves are aluminium and have a special silicon finish on them and to the response of .020 not being alot to the eye its not alot but when it comes to machining it is .001 is normal when you have .004 you exceed some service limits why i tell people to sleeve h22a motors is so they can use which ever piston they want when you bore a h22a you must resilicon the sleeve you cant even hone it
How true is this statement? Doesn't the manual say that you can actually hone the walls?
Old Sep 13, 2010 | 10:57 AM
EG1834's Avatar
Default Re: H block hone statement
I typically don't put much faith in the words of someone who writes that poorly. I mean seriously, that's pretty bad!
So apparently you can hone the FRM sleeves, just not like you can other engines with trypical ductile iron liners.
Old Sep 13, 2010 | 02:19 PM
EGPrelude's Avatar
If you do need to hone a H-series block, Golden Eagle Manufacturing can do it. They have the proper stones and have experience with the FRM liners.
Old Sep 13, 2010 | 05:13 PM
Nocture's Avatar
How much does honing an H usually cost?
Old Sep 14, 2010 | 03:39 PM
Golden Eagle's Avatar
This, LOL.
Pm sent.
TravisBiggie
Oct 18, 2013 05:08 AM
Woody.
Apr 12, 2011 11:06 PM
2LiterTurboSeR
Jan 9, 2010 02:29 PM
DragSource
Mar 31, 2005 11:26 AM
x916
Oct 27, 2003 06:42 PM
