94 del sol won't crank
Old Sep 12, 2010 | 08:24 AM
maphil's Avatar
Default 94 del sol won't crank
have been having intermittant starting issues. I replaced the solenoid but still have problem. It will start if I run wire from battery to solenoid. I am only getting 4 v at solenoid when trying to start normally. I switched places with the start cut relay, you can feel it click when key is moved to start. I am getting 12 volt at wire connector coming through firewall that goes to solenoid with solenoid disconnected, but 4v if connected??????
Old Sep 12, 2010 | 08:49 AM
Former User's Avatar
Default Re: 94 del sol won't crank
Your starter may be bad.
Old Sep 12, 2010 | 08:51 AM
MadVTI's Avatar
id try a atarter, may have a resistance.
romomatic
Jun 24, 2013 12:57 PM
MattyDSol
Jun 21, 2011 09:07 AM
MrMug3n
Nov 25, 2010 11:26 AM
Matthew_zero
11
Mar 31, 2010 09:13 AM
jachrist
Feb 5, 2010 10:46 AM
