high compression on 93 octane
Old Sep 18, 2002 | 01:22 PM
hatchmobile's Avatar
Default high compression on 93 octane
i tried searching for this, but could not find enough helpful information. i'm going to being ruuning a b18c1 block w/ ctr pistons all on a b16 head...according to c-speed the compression ratio is about 11.76:1. know how safe am i running that on 93 octane. right now i have a skunk2 program and a v-afc for tuning purposes. will this all be possible without detonating bad or should i run lower compression??? thanks in advance
Old Sep 18, 2002 | 04:31 PM
NVMYSi's Avatar
Default Re: high compression on 93 octane (hatchmobile)
You will be fine with 93 octane, 92 still ok but not as good. DO NOT put anything less than 92 in the car!!! I would put a couple of bottles of octane booster in the spare tire area just incase you get caught in a jam and need the extra octane.
Old Sep 18, 2002 | 11:09 PM
Default Re: high compression on 93 octane (NVMYSi)
thanks for the reply. the only thing that i was wondering is if i'm going to detonate in low rpm's because of the skunk2 program...it runs pretty aggressive low rpm timing. the only really tuning device that i have right now is the v-afc, but i was just wondering if i was going to safe w/ this set-up. thanks again for the reply
Old Sep 19, 2002 | 06:16 AM
NVMYSi's Avatar
now you have me stumped on the low rpm stuff??? That is a good question. I have a project exactly the same as yours being built currently (except my block is a B18C5 ).
EliTe 93Lude
Jul 31, 2006 07:18 PM
92eg6
23
Mar 11, 2006 07:50 AM
hondab18civic
Feb 6, 2006 07:24 AM
redteg
Apr 23, 2003 10:56 PM
Chuji
Oct 30, 2001 07:26 PM
