'99 EX manual tranny. 4 cyl. hesitation when A/C is on??
Old Sep 10, 2010 | 01:45 PM
shortlid's Avatar
Icon2 '99 EX manual tranny. 4 cyl. hesitation when A/C is on??
I get a hesitation out of the engine '99 Accord Ex sedan 4cyl with my 5-speed manual transmission when the A/C is on. Looked at the front motor mount, the rubber bushing was cracked. So I got a Anchor brand mount for $25 from Advanced autoparts. Sound like a fix, or what crew?
Old Sep 10, 2010 | 04:06 PM
poorman212's Avatar
Default Re: '99 EX manual tranny. 4 cyl. hesitation when A/C is on??
I'm betting that the mount isn't the issue, still needs to be replaced. Start with that.
Is there a certain RPM range for the hesitation? (tune up needed?). AND this only happens with the AC is on, under load.
Old Sep 10, 2010 | 05:54 PM
phootbag's Avatar
Exactly when does the hesitation occur? RPM, gear, take-off? etc..
Old Sep 11, 2010 | 04:13 AM
shortlid's Avatar
Seems to happen only when compressor is engaging AND I am in first or second gear and accelerating. Does not happen when at idle and the compressor engages. Or at cruise in higher gears? Only lasts a split second.
Old Sep 11, 2010 | 05:01 AM
HondaPartsHero's Avatar
Technical Hero
Thats normal, because its putting load on the motor to turn the compressor when the compressor clutch engages, my 96 auto does this as well
Old Sep 11, 2010 | 12:40 PM
phootbag's Avatar
Agreed.
Old Sep 12, 2010 | 07:06 AM
shortlid's Avatar
Then why has it not occured atleast noticbly so, for the last 40,000 miles?? Is Anchor brand a good brand of motor mount??
Old Sep 12, 2010 | 07:10 AM
Technical Hero
If the motor mount (rear or front) is bad the "shock" from the engagement will probably be more noticeable and felt throughout the car. I need to check my front and rear mount soon because I have a clunk when shifting from park to drive and then the shift from 1st to 2nd, I believe it is the rear L bracket hitting the rear subframe.
Old Sep 12, 2010 | 09:27 AM
shortlid's Avatar
Ok, thanks PartsHero so the mountcould have something to do with the engagement being more noticable. Also I would rather replace one $25 mounts then what looks like more expensive mount on the side of the engine and tranny!
Nisif
Jul 16, 2012 06:05 AM
nastynx2k
Jul 11, 2010 02:31 PM
94eh2
12
Sep 25, 2009 05:54 PM
lsvtec101
Apr 27, 2004 08:25 AM
