Suspension & Brakes Theory, alignment, spring rates....
Does the asr 24mm sway bar with brackets bolt onto function7's 96-00 subframe brace?
Old Sep 8, 2010 | 07:40 AM
jdmdohcek98's Avatar
Default Does the asr 24mm sway bar with brackets bolt onto function7's 96-00 subframe brace?
So right now i have f7 rear lca's, asr subframe brace, asr 24mm swaybar. A buddy of mines really wants to buy my asr and I do like the look of the f7 subframe brace. So I wanted to know if anybody has tried using the asr 24mm sway bar and polished D-brackets with the new f7 subframe brace? This is on the 96-00 civic chassis by the way. I dont want to have to use any universal D-brackets i want to be able to use the asr sway bar and hardware bolt it up and go. Thanks in advanced.
Old Sep 8, 2010 | 06:47 PM
Default Re: Does the asr 24mm sway bar with brackets bolt onto function7's 96-00 subframe bra
bump
Old Sep 10, 2010 | 08:22 AM
bump
Old Sep 14, 2010 | 02:04 PM
bump
Old Sep 14, 2010 | 02:46 PM
VVENOM800TT's Avatar
Call function 7 guy
Old Sep 15, 2010 | 07:37 AM
Function7's Avatar
It should fit. We've seen pictures of customers sporting the ASR D-brackets with our braces.
Old Sep 16, 2010 | 05:45 PM
any pics? should fit isnt convincing. what brand 24mm rear sway bar will work with your subframe brace that your sure of?
Old Sep 17, 2010 | 08:22 AM
Function7's Avatar
I've seen the pics floating here on H-T. Too bad, but I should have saved them.
Any brand sway bar will work with our braces. If the supplied D-brackets do not fit (which is a very rare scenario), you can get the universal sway bar brackets/bushing kits (Energy Suspension kits) from us that accomodate any size from 11mm to 35mm.
We usually carry the standard/common bracket & bushing kit sizes in stock (13, 19, 22, 23mm) and for any other size it's a special order - the cost is somewhere around $25-$30 for a pair. You can also order them from Energy Suspension directly (we'll be glad to give you the part # if you know what size you need).
-A
Old Sep 17, 2010 | 11:35 AM
dgerej2's Avatar
^ good to know.
eg7
52
Jan 28, 2011 05:02 PM
turb0teg
May 4, 2008 07:23 PM
blackstar
Sep 27, 2005 02:17 PM
EK-Cruiser
Aug 30, 2004 08:15 AM
MrIllegalX
Jan 20, 2004 05:52 AM
