trans case leaking
Old Sep 8, 2010 | 04:34 AM
MattNYC's Avatar
Default trans case leaking
i have a 98 ls trans 5speed and it looks like the case is leaking. would i have to dismantle the case and re-hondabond it? theres no grinds or any problems w the trans to begin with. i just only found out now because i just started driving it.
Old Sep 8, 2010 | 05:21 AM
Former User's Avatar
Default Re: trans case leaking
If fluid is leaking at the seam between the clutch and transmission housings, then you must remove the transmission, separate the clutch and transmission housings, and re-Honda Bond it. Are you sure the fluid is not coming from an axle seal? Are your sure the leak is not engine oil?
x_40oz
Nov 20, 2013 11:45 AM
Bradshaw
Jul 23, 2011 10:08 PM
ekcoupe88
14
Sep 24, 2007 07:39 AM
gsrboi80
Nov 1, 2004 05:14 AM
foeverchillin
Sep 29, 2004 06:21 PM
