trans case leaking
trans case leaking
i have a 98 ls trans 5speed and it looks like the case is leaking. would i have to dismantle the case and re-hondabond it? theres no grinds or any problems w the trans to begin with. i just only found out now because i just started driving it.
Re: trans case leaking
If fluid is leaking at the seam between the clutch and transmission housings, then you must remove the transmission, separate the clutch and transmission housings, and re-Honda Bond it. Are you sure the fluid is not coming from an axle seal? Are your sure the leak is not engine oil?
Bradshaw
07-23-2011 10:08 PM
