95 civic dx into 96 civic ex
Old Sep 7, 2010 | 09:35 AM
95civiccpdx's Avatar
Icon2 95 civic dx into 96 civic ex
I have a complete 95 civic hatchback I just recently purchased a 96 civic ex two door shell it came complete except the motor and trans unfortunately my funds are very low and my hatch back is totaled so I want to take my d15b7 and put it into the 96 ex the car already has the step down harness to use the obd1 ecu but what else will I need as far as mounts t brackets can I use anything from my motor or do I have to purchase all new things?? Thank you in advance
Old Sep 7, 2010 | 10:32 AM
HarosGSRek's Avatar
Default Re: 95 civic dx into 96 civic ex
get an obd2 dizzy or get the rywire adapter to use yours $30 with the ek harness (1piece) eg is 2 peice harness
Old Sep 7, 2010 | 10:37 AM
What about the t bracket and shift linkage are they compatible or do I have to use ek parts???
Old Sep 7, 2010 | 10:39 AM
HarosGSRek's Avatar
shift linkage and axles are the same.
rear T bracket should be the same. the driverside mount i think is differnt though.
make sure you keep the obd1 conversion and ecu. itl keep you from having 3245345 CELs
Old Sep 7, 2010 | 10:55 AM
Ok thanks for the help
Old Sep 8, 2010 | 05:34 AM
Ok so I have everything in the car the only thing I am having a problem with is wiring the obd1 distributor plug onto the harness does anyone have a detailed wiring diagram on how to wire them together
hYbRid_Eg6
Apr 6, 2009 12:46 PM
Supahatch
Nov 15, 2005 10:11 AM
intrex
Apr 14, 2004 07:44 PM
bmxmarine
Oct 7, 2003 09:22 PM
Thagreybomber
Jun 20, 2002 07:01 PM
