Compression Test Results B16a2
Old Sep 7, 2010 | 08:34 AM
acake em1's Avatar
Colonel Cake Mix
Default Compression Test Results B16a2
Motor B16a2 Completely Stock w/ 132k miles
The results are as follows:
-140
-140
-130
-145
From what I know these results are in the normal wear in tear range for a motor w/ that kind of mileage. The motor was warm, would that have made a difference on the results? Any other input is welcome.
Thanks HT
Old Sep 7, 2010 | 09:58 AM
98civdx's Avatar
Master Detailer
Default Re: Compression Test Results B16a2
I can't say if it being warm or not would effect it, becuase I don't know.
But, my friends b16a2 with around 90k put 220psi+ across the board.
Correct me if wrong but honda say's 130 or so psi is the lowest?
Old Sep 7, 2010 | 10:10 AM
dizzyroc88's Avatar
with the motor warm you get the highest numbers vs it being cold. your supposed to do it warm.
i would start preparing for a lil rebuild. fresh gaskets, rings, and bearings. those numbers are playing with the low end range
Old Sep 7, 2010 | 11:56 AM
Markley02's Avatar
Did you have the throttle open when you did the test? Those numbers are pretty low.
Old Sep 7, 2010 | 12:44 PM
acake em1's Avatar
Colonel Cake Mix
I was just cranking the motor... I don't think it was WOT now that I think about it. How big of difference is that gonna make?
Old Sep 7, 2010 | 12:45 PM
98civdx's Avatar
Master Detailer
My freind did that when he did his, the numbers were considerbly lower then wide open.
Try doing it again but drop a little oil in each.
Old Sep 7, 2010 | 12:47 PM
acake em1's Avatar
Colonel Cake Mix
Aright I'll probably have to do this one on my own then. Thanks guys
Old Sep 8, 2010 | 08:30 AM
Cynical 1's Avatar
yes, have the trottle at wot and the fuel pump disabled.
take the readings like that, then squirt a bit of oil in each cylinder and do it again - if the numbers after the oil rise, then your rings are going... if not, then it is a valve related issue...
Jm920
May 4, 2015 03:10 PM
ChicagoMike
Jul 14, 2006 01:30 PM
mugenhatchie
Apr 3, 2006 12:31 AM
JDM92Bubble
Feb 26, 2006 04:40 PM
B18EG6
Jan 29, 2006 02:24 AM
