Compression Test Results B16a2
Colonel Cake Mix
Motor B16a2 Completely Stock w/ 132k miles
The results are as follows:
-140
-140
-130
-145
From what I know these results are in the normal wear in tear range for a motor w/ that kind of mileage. The motor was warm, would that have made a difference on the results? Any other input is welcome.
Thanks HT
-140
-140
-130
-145
Thanks HT
Re: Compression Test Results B16a2
I can't say if it being warm or not would effect it, becuase I don't know.
But, my friends b16a2 with around 90k put 220psi+ across the board.
Correct me if wrong but honda say's 130 or so psi is the lowest?
with the motor warm you get the highest numbers vs it being cold. your supposed to do it warm.
i would start preparing for a lil rebuild. fresh gaskets, rings, and bearings. those numbers are playing with the low end range
Colonel Cake Mix
I was just cranking the motor... I don't think it was WOT now that I think about it. How big of difference is that gonna make?
yes, have the trottle at wot and the fuel pump disabled.
take the readings like that, then squirt a bit of oil in each cylinder and do it again - if the numbers after the oil rise, then your rings are going... if not, then it is a valve related issue...
mugenhatchie
04-03-2006 12:31 AM
B18EG6
01-29-2006 02:24 AM
