clicking noise, not from axles
Old Sep 6, 2010 | 06:33 PM
jyacoba2009's Avatar
Default clicking noise, not from axles
i got a d16z6 and I got a weird clicking sound coming from my engine bay, can't pin point it, I didn't hear it from the head. Only occurs doing start up and when I'm not pressing the clutch, so transmission problem?
Old Sep 6, 2010 | 07:50 PM
Former User's Avatar
Default Re: clicking noise, not from axles
If the noise goes away when pressing down the clutch pedal, then you may have a bad mainshaft/input shaft bearing.
Also check for a loose or cracked exhaust heat shield.
Old Sep 6, 2010 | 10:16 PM
thanks Ron, just checked my exhaust shield, all good.. I wish it weren't though, lol.
rough estimate for a shop to replace either or?
Old Sep 6, 2010 | 10:53 PM
ED94LIFE's Avatar
It wouldn't be a throw out bearing?
Old Sep 6, 2010 | 11:36 PM
naidoona's Avatar
Hi guys, i also have a problem with a low-pitch noise sound coming coming from the engine....just below the injectors. i'm not sure what it is but the sound has been there ever since i bought the car, but it's getting worst now. it only happens when i take off from rest and then goes away when i drive....could this be a problem with the gear box mounting? the sound is probably stimulated by some mechanical vibration, something that's loose somewhere...i need to try and pin point the problem...can anyone assist? it's a honda ballade 160i 97...
Old Sep 6, 2010 | 11:42 PM
noz79's Avatar
it is a possibility
Old Sep 7, 2010 | 11:27 PM
ED94LIFE's Avatar
Are you sure it's not the injectors clicking that you're hearing?
Trevo Badri
Transmission & Drivetrain
Apr 4, 2019 12:44 PM
DaveSi677
Nov 4, 2008 07:18 AM
4everVtec
11
Nov 14, 2006 04:44 PM
redpeppers
12
May 18, 2006 12:49 PM
DA jeshy
Mar 6, 2006 12:24 PM
