clicking noise, not from axles
i got a d16z6 and I got a weird clicking sound coming from my engine bay, can't pin point it, I didn't hear it from the head. Only occurs doing start up and when I'm not pressing the clutch, so transmission problem?
Re: clicking noise, not from axles
If the noise goes away when pressing down the clutch pedal, then you may have a bad mainshaft/input shaft bearing.
Also check for a loose or cracked exhaust heat shield.
thanks Ron, just checked my exhaust shield, all good.. I wish it weren't though, lol.
rough estimate for a shop to replace either or?
Hi guys, i also have a problem with a low-pitch noise sound coming coming from the engine....just below the injectors. i'm not sure what it is but the sound has been there ever since i bought the car, but it's getting worst now. it only happens when i take off from rest and then goes away when i drive....could this be a problem with the gear box mounting? the sound is probably stimulated by some mechanical vibration, something that's loose somewhere...i need to try and pin point the problem...can anyone assist? it's a honda ballade 160i 97...
DaveSi677
11-04-2008 07:18 AM
redpeppers
12
05-18-2006 12:49 PM
