engine coolant tempurature sensor check engine light
Old Sep 18, 2002 | 08:26 AM
tunes12's Avatar
Default engine coolant tempurature sensor check engine light
I just did a jdm b16a swap into a 91 crx si. Everything went fine, ever since I first started it I've gotten a code 6, ect sensor. Where is this sensor on the engine? If it is the one by the vtec pressure sensor, under the distributor, I have checked it and it is fine. What else could it be? Would this cause the vtec to not work? I am also getting a tps light, code 7. Does this have anything to do with it? Any help would be excellent thanks.
Old Sep 18, 2002 | 08:33 AM
jdmcx's Avatar
Default Re: engine coolant tempurature sensor check engine light (tunes12)
i had the same thing go wrong with mine i did an ls vtech in a 92 hatch and i replaced the sensor and it went away
mtime
Dec 17, 2009 09:17 PM
99d-series
May 1, 2009 08:56 AM
pancake
May 4, 2008 02:17 PM
Oreo-TeCk
May 21, 2007 09:39 AM
HATCHFREEK
Mar 19, 2003 10:32 AM
