cel code 9. replaced dizzy,ecu,wiring. wtf!
Old Sep 5, 2010 | 02:48 PM
nello a.'s Avatar
Default cel code 9. replaced dizzy,ecu,wiring. wtf!
1993 del sol
jdm b20
cel code 9
replaced dizzy(new)
replaced cyp orange and white wires from dizzy to ecu.
replaced ecu(known to be good)
at a loss and really angry.
searched a long time. no help.
ideas please. thanks
Old Sep 5, 2010 | 06:41 PM
nello a.'s Avatar
Default Re: cel code 9. replaced dizzy,ecu,wiring. wtf!
no one?
Old Sep 5, 2010 | 09:01 PM
Former User's Avatar
At ECU connector B, what resistance do you measure between B11 and B12? Have you tested for a short to ground at terminals B11 and B12?
Old Sep 6, 2010 | 07:15 AM
nello a.'s Avatar
i appreciate that. is it 350-700 ohms ?
short to ground would be continuity between body ground and b11 or b12 -correct?
have not used a tester in awhwile. what does the symbol look like on the meter to test for continuity? just looked at it and cant remember.
would jumping a wire between 4,8 on dizzy plug to b11,b12 ecu plug eliminate any need to test the harness? dony know what the circuit looks like and could not find it searching. not very good with electrical stuff.
thanks
on another note- is it ok to use ANY OBD1 LS DIZZY?
Old Sep 6, 2010 | 06:10 PM
nello a.'s Avatar
441 ohms.
cant figure it out. troubleshooting flowcharts are not helping. they say test continuity to ground. test resistance. change ecu. change dizzy. did all of it. still get the code.
car has a slight miss too.
Old Sep 6, 2010 | 06:19 PM
Originally Posted by nello a.
441 ohms.
441 Ohms between b11 and b12, right?
With the distributor plug connected, now test for a short to ground individually at b11 and b12. Again set the multimeter to read Ohms on a low Ohm scale such as 20 or 200 Ohms. Touch one meter probe to b11 and the other to body ground. Do the same for b12. What are your readings?
Old Sep 7, 2010 | 10:32 AM
nello a.'s Avatar
i put it on the beep setting and tested for continuity to ground individualy on b11 and b12 with the dizzy plugged in. the ecu was not plugged in. does that make a difference? i will do it again on low ohm setting. got no continuity on beep setting though.
Old Sep 7, 2010 | 07:32 PM
nello a.'s Avatar
another mechanic looked at it. did a "bunch of tests". dont know what. proly the same stuff i have done. no solution.
i cannot even think of a way to "rig up" a fix.
need some quirky honda info.
does the dizzy share a ground with something else?
getting the wiring diagram tomorrow.
will test for continuity to ground again but dont think thats it. unless it is an intermittent break.
having to think alot on this one. who wants to think with me?
anyone have a problem like this with another dizzy code or even another sensor? any ideas even if they seem unrelated.?
Old Sep 8, 2010 | 06:33 AM
nello a.'s Avatar
anyone.
should ask which lip looks best on my da. bet i would get 50 people in here then.
honda-technicalyanappearanceforum.com
Old Sep 9, 2010 | 10:06 AM
nello a.'s Avatar
going to the car now. guess i need luck. not tech
Old Sep 9, 2010 | 10:16 AM
Do the distributor and engine match with the ECU?
Are CYP wires correctly pinned to the ECU?
Old Sep 10, 2010 | 11:44 AM
nello a.'s Avatar
stock 93 sol harness. b11 and b12 in the cvorrect spot. ecu plugs were uncut till i cut them and ran b11 and 12 directly to the dizzy. the engine harness is not a 93. it has a map sensor plug and the 93 sol has the map sensor plug coming from the shock tower area of the chassis harness. the chassis harness map plug is the one being used. no code for that though.
the ecu is a 92 pr4.
the dizzy is a 92 ls teg reman.
motor is a jdm b20 1996.
new cap. new wires. new ngk plugs.checked valve clearance. compression 170-180-180-180 . 4-3-2-1. timing is right. cam sprockets tight. balancer tight. scraped engine grounds to new metal.
is there any issue with that motor and 92 ls dizzy and/or ecu?i know the fuel maps are not perfect. is not the head the same as an ls?would not the timing be the same?
motor had an obd2 gsr dizzy with the ears cut off(held in by one bolt) and threw code 9 with all else equal. also tried everything else with this dizzy before switching to the new reman.
cant think of anything else that is relevant. everything checks out but the car misses and throws this code.
really getting angry now. have not gotten wiring diagram yet. will get it this weekend.
Old Sep 13, 2010 | 07:49 PM
nello a.'s Avatar
nothing.
had some bad luck with my girls car so did not get to work on it.
car was supposed to be taken to another mechanic today.
i have the wiring diagrams now and have some ideas onwhat is going on. will try them if i get the car again.
as usual, any help is appreciated until the problem is solved.
Old Oct 7, 2010 | 01:19 PM
SPL KID's Avatar
any luck on this yet? I have the same problem with my 94 civic with B18a1 in it and PR4 ecu. I think it's my ECU.
91efbluehatch
21
May 30, 2017 10:19 AM
Rob91DA
Nov 18, 2008 05:10 AM
pchris52
Nov 9, 2006 07:15 AM
pchris52
Nov 9, 2006 06:51 AM
iphatcrxi
11
Jul 2, 2006 11:21 AM
