intercooler/head gasket question
Old Sep 3, 2010 | 07:41 PM
sh!ft's Avatar
Who the fack changed my title?!
Default intercooler/head gasket question
ok so i figured id ask a 2 for 1 special question all in the same thread.
question 1: what is a good sized intercooler(dont care about brand unless its completely necessairy) that will fit under the front bumper of an ef hatch;that will support up to 5 or 600 hp? and will i need to cut the front reinforcement bar in order to make it fit.
question 2: i am having my block bored to 81.5mm and running a block guard. which gasket will be best suited for me? daily driven, and should i get a gasket with copper rings or not?
Old Sep 3, 2010 | 07:59 PM
BLU CIVIC's Avatar
Track Advocate
Default Re: intercooler/head gasket question
Precision 600hp intercooler
Originally Posted by ESP.net
Looks nice when I got mine installed Precision 600hp IC I thought at the time I could even fit the 750hp one but be overkill for me... koo to see one installed...
Precision 750hp intercooler
Originally Posted by Aladar
Well, i decided to post my stuff up. Had a small Ebay intercooler, and small charge pipes, so ordered a Precision 750HP, and 3 inch charge pipe kit. I was determined to make the stock CRX bumper fit with core support and all. And I did it, here are a few pics. Any questions PM me.
Old Sep 3, 2010 | 08:15 PM
ROMEO856's Avatar
precision 600hp ic will work right and give you a clean look, will fit with slightly cutting into your bumber support if you wanna keep it.
also for 600 hp you need to consider what gas and what pumps you will be using ...
1000cc will be good if on pump gas with a inline/intank set up, race gas will require something bigger...
Old Sep 3, 2010 | 08:18 PM
sh!ft's Avatar
what are the measurements of that intercooler from precision
Old Sep 3, 2010 | 08:26 PM
BLU CIVIC's Avatar
Track Advocate
http://www.precisionturbo.net/Wc21126d5f695d.htm
PIN 053-1010 600-hp 31 1/2" L x 8" H x 3 1/2" D 2 3/4"
PIN 053-1515 750-hp 31 1/2" L x 10 5/8" H x 3 1/2" D 2 3/4"
crxaggtown
Jun 5, 2007 10:02 PM
boostjunkieee
Mar 30, 2007 03:07 PM
adotlee
Jan 13, 2004 10:37 PM
1sloaccord
Mar 31, 2003 08:01 PM
