Need some advise Hondata
Old Sep 2, 2010 | 03:40 PM
Honda1949's Avatar
Default Need some advise Hondata
Hi to All..Need some help..We are running the s300 in a 2000 Honda civic B16 .The car currently puts out 583hp /379 Best time to date 10.78 133.We have been playing with the boost by gear settings and find through the datalogs that we are hitting the target boost in 1st 3rd 4th and for some reason not in second. the current settings in second are 28lbs but we will only get 24.The other boost settings are hitting their goal and spiking a little.The cars is tuned to 34lbs.The tuner has recorded all the logs and been at the track when we run so everything is in real time.I bought the wastegate with the 18psi spring(No I never opened it up) just assumed. I don't think its the spring cause everything else looks OK . The tuner wants to lower the spring psi to see if its a load issue. Hope this makes sense.Any Thoughts.............Thanks
98B18C1
Mar 26, 2013 10:35 AM
GReddy SI
Mar 2, 2010 08:10 PM
Eklsv-t
Nov 13, 2007 04:53 PM
BlackThorN
Dec 21, 2003 12:51 AM
5thgencivic
Sep 17, 2003 06:41 PM
