Window problems?
I got a 96 civic that constently comes off the track.... i put some tire cleaner spray where the weather stripping is on the window for driver side it works easy not and doesnt come off track. i did it to passanger side and it still comes off track when its all the way down and u slam the door... or when ur parked on a Hill like a steep hill
check the track.the bushings that hold it together tend to wear down.you can replace the track with a brand new one from honda.dont go with the aftermarket ones.they fit like ****.the track flexes in a bad way when the wear down.g/l.
it sound like the the plastic tabs that are glued to the window have came unglued the tabs are what allow the window to be held in place on the regulater a simple chek would be to roll the window up half way grab it in the corners and move up and down .
inaety
Nov 3, 2009 08:20 PM
