b16a cutting out in vtec
Old Sep 1, 2010 | 04:28 PM
CivicSi95's Avatar
Default b16a cutting out in vtec
i have a jdm b16a with a p30 swapped in a 95 Si for about 2 years now. ive never had one problem with my engine until recently. i also cleaned my engine bay a few months ago so im wondering if that could have led to my engine problems. i only covered up the alternator so it couldnt get wet. however, i didnt blast anything with a power washer, i just lightly sprayed the water over everything with my water hose and a spray nozzle turned all the way down. im not sure if these 2 occurences have anything to do with each other, i just thought i would put this information out there just in case
my car is running fine under vtec. no stalling, no bogging, it runs perfect under 5xxx rpm's. once i get into vtec, it is cutting out and runs like crap. it will not make a smooth pull all the way to 8k rpm's without cutting out in vtec
today i decided to clean the iacv, new oem dist. cap and rotor, new oem fuel filter, new oem ngk spark plugs. i have some ngk plug wires that still look to be in good condition. after all this, it's still running the exact same.
Old Sep 1, 2010 | 06:02 PM
Former User's Avatar
Default Re: b16a cutting out in vtec
Any CEL codes? You might want to test the coil and igniter unit.
Old Sep 1, 2010 | 06:13 PM
honda fossil's Avatar
check the gasket for the vetec pressure switch the gasket has a wire mash screen that clogs up
Old Sep 1, 2010 | 06:26 PM
CivicSi95's Avatar
no CEL
are you referring to the vtec solenoid?
Old Sep 1, 2010 | 06:42 PM
yeah sorry too many going on. the vtec solenoid remove it and check the gasket
Old Sep 2, 2010 | 07:08 AM
CivicSi95's Avatar
drove my car to work today and it ran excellent. it pulled hard all the way thru vtec up to 8k rpms without cutting out. i dont get it. yesterday it ran like **** and today it ran excellent. i havent done anything else to it other than what i stated in the first post
CanoTech88
21
May 2, 2012 04:32 PM
Sabres_e
Oct 17, 2009 08:40 AM
bonylad
Oct 3, 2006 02:33 PM
GEN2 HYBRID
Oct 19, 2002 07:19 PM
NateDawgCRX
Sep 23, 2002 09:13 PM
