Columbus, OH -- In search of help OPENING HOOD!
Old Aug 31, 2010 | 06:54 PM
Blackknight103's Avatar
Default Columbus, OH -- In search of help OPENING HOOD!
Hey guys, I was messing around with the latch under my hood on my '93 hatchback and I think I messed something up with the wire connecting the latch under the hood to the lever inside the car. I have done tons of research on the subject and tried a few different techniques over the last 2-3 days to get the hood open including:
Pulling the wire (inside car) with pliers
Flathead screwdriver in between hood and bumper
Im located near campus in Columbus off High and Chitenden. Any help is better than none!
Thanks
Old Aug 31, 2010 | 08:30 PM
4dohs4mohoes's Avatar
Default Re: Columbus, OH -- In search of help OPENING HOOD!
Thanks
So what happened when you pulled the cable with the pliers? Does the cable move at all? Is there alot of slack, or calbe exposed inside the car?
Old Sep 1, 2010 | 07:15 AM
Yes the cable has roughly 2-3 inches of slack now since I pulled on it, and now it wont pull any further. It pulled a little then just stopped as if it was stuck on something. I tryed putting roughly 20-25 pounds of pressure on it with the pliers and it wont budge. Any more and it seems like it would snap.
Old Sep 1, 2010 | 08:00 AM
grumblemarc's Avatar
The Grumpiest
Sounds like you disconnected it from the latch.
Old Sep 1, 2010 | 09:44 AM
Yeah thats what I was thinking. I just need help opening it then I could probably fix it myself.
Old Sep 1, 2010 | 09:47 AM
Green Crack's Avatar
So the cable is no longer attached the latch assembly?
Old Sep 1, 2010 | 01:36 PM
I think its still connected because the cable is tight when I try pulling on it from inside the car but Im not 100% sure. Is there any way I can pop the hood from the outside because if I could just get the hood open I could figure out the problem.
Old Sep 1, 2010 | 01:50 PM
Former User's Avatar
Remove the splash guard to see whether it gives you access to the latch and cable from below the car.
Old Sep 1, 2010 | 02:11 PM
Pothole987's Avatar
if i remember correctly, the latch which attaches to the cable is at the very front. If you are able to reach through the grill behind the rebar you may be able to flick the latch.
Old Sep 1, 2010 | 06:06 PM
Thanks. Ill try it tomorrow.
Old Sep 1, 2010 | 06:44 PM
Got it! Thanks HT!
Old Sep 1, 2010 | 08:50 PM
Got it! Thanks HT!
Woohoo... Now dont close the hood again till you fix it.
Jason P
Dec 21, 2009 04:28 PM
AznBlueBoy
Aug 29, 2009 08:39 AM
1989 Honda Accord
Feb 7, 2007 08:43 AM
sohc_coupe24
Aug 22, 2005 06:21 PM
bey
12
Aug 11, 2003 07:49 AM
