B18C1 parts list good?
Old Aug 30, 2010 | 09:08 PM
97dssi's Avatar
Default B18C1 parts list good?
B18C1 engine
Parts:
port and polish block and head
Hasport engine mounts
ARP studs
RS Machine dome piston 84mm
Eagle Connecting rods
Walbro fuel pump
Skunk2 Black Series Pro Series Cam gears
Skunk2 Tuner Series Stage 3 Camshaft
Skunk2 B-series VTEC Pro Series Valve set
Skunk2 B-series VTEC Titanium retainer set
Skunk2 B-series VTEC Tuner series valve spring set
Skunk2 B-series composite fuel rail
Password JDM carbon fiber intake
Skunk2 Black Series 70mm Billet Pro Series Throttle Body
Password JDM Magnetic oil and Tranny drain plug
Skunk2 Black Series B18 type r Intake Manifold? can this fit ?
NGK spark plug set?
Header- not sure which is best one..
Type r oil pump? will it work?
What kind oil pan? stock or better one?
what kind timing belt? OEM or what?
What kind Injector? RC 550cc??
what kind flywheel? Exedy lightweight?
What kind clutch? act or exedy? 4 or 6 puck? which one is the best?
Bolt boys B-series kit? good?
should I get oil catch can?
should i get a fuel pressure?
OEM dizzy?
can I use racing fuel and pump gas?
let me know if i am missing something
thanks
Old Aug 31, 2010 | 08:07 AM
97dssi's Avatar
Default Re: B18C1 parts list good?
TTT
Old Aug 31, 2010 | 11:15 AM
lunatics209's Avatar
Originally Posted by 97dssi
B18C1 engine
Skunk2 Black Series B18 type r Intake Manifold? can this fit ? NO
NGK spark plug set? NGK platinum 9's
Header- not sure which is best one.. Hytech, SMSP, DTR/SSR
Type r oil pump? will it work? YES
What kind oil pan? stock or better one? STOCK
what kind timing belt? OEM or what? OEM
What kind Injector? RC 550cc?? 440's if using any other fuel besides E85
what kind flywheel? Exedy lightweight? Lightweight is ok
What kind clutch? act or exedy? 4 or 6 puck? which one is the best? Clutchmasters single or twin
Bolt boys B-series kit? good? WHAT?
should I get oil catch can? Catch cans a must for high compression or high output motors
should i get a fuel pressure? YES
OEM dizzy? YES
can I use racing fuel and pump gas? Any gas depending on your wallet, E85 preferred
let me know if i am missing something....
thanks
Old Aug 31, 2010 | 11:53 AM
ruffrhyder's Avatar
Why on earth would you recommend the NGK 9's for an all motor build?
Old Aug 31, 2010 | 12:12 PM
Why wouldn't I? I run 9's in my high compression all motor buid. My tuner suggested 7,8,9 so I had 9's on hand and thats what I ran. Just go google everyone recommends 8's or 9's for high compression all motor builds. What do you suggest?
Old Aug 31, 2010 | 01:17 PM
TheShodan's Avatar
Moderator
7's worked fine for me. 9's are over 14.0:1 and 15.0:1. Even turbo cars don't run anything more than 8s, and those are over 500whp or so and need the extra spark.
Old Aug 31, 2010 | 05:04 PM
ruffrhyder's Avatar
Who is your tuner? What CR are you running? HP output?
If a tuner gave me a blank statement suggesting 7-9 heat range without thoroughly discussing the build, I would find another tuner immediately.
I'm with shodan. 7's have worked fine for most all motor builds. 99% of the all motor builds I've built with CR ranging from 11:1-13:1, hp ranging from 170-230 whp run perfect with 7's. Post pics of your plug's ground straps. I almost gaurantee you are running too cold of a plug.
Old Aug 31, 2010 | 05:19 PM
all-mtr-teg's Avatar
My take on this build.
B18C1 engine
Parts:
port and polish block and head - Good if done right.
Hasport engine mounts - Good
ARP studs - Good
RS Machine dome piston 84mm - Good
Eagle Connecting rods -Good if checked
Walbro fuel pump - Good
Skunk2 Black Series Pro Series Cam gears - Good, just make sure not to overtorque the adjustment bolts
Skunk2 Tuner Series Stage 3 Camshaft - Good
Skunk2 B-series VTEC Pro Series Valve set - Good
Skunk2 B-series VTEC Titanium retainer set - Good, just check often for abnormal wear
Skunk2 B-series VTEC Tuner series valve spring set - Good
Skunk2 B-series composite fuel rail - Not needed
Password JDM carbon fiber intake - Get a better intake
Skunk2 Black Series 70mm Billet Pro Series Throttle Body - Good for top end, not so much for low and mid range
Password JDM Magnetic oil and Tranny drain plug - Good insurance
Skunk2 Black Series B18 type r Intake Manifold? can this fit ? Won't fit
NGK spark plug set? 7's or maybe 8's
Type r oil pump? will it work? Same as GSR
What kind oil pan? stock or better one? Stock is fine
What kind Injector? RC 550cc?? 370's are fine
what kind flywheel? Exedy lightweight? Exedy is good
What kind clutch? act or exedy? 4 or 6 puck? which one is the best? 6 puck is fine
Bolt boys B-series kit? good? No idea
should I get oil catch can? Won't hurt
should i get a fuel pressure? Adj. FPR and gauge
OEM dizzy? Yes
can I use racing fuel and pump gas? Pump is fine
thanks
Old Aug 31, 2010 | 06:52 PM
97dssi's Avatar
if you dont know about bolt boys... here is the link http://downstarinc.com/Shop/index.ph...d&productId=20
which is better intake? should i get eagle rods or OEM rods? what about Brian Crower Valve Spring & Retainer Kits, Valves, and cam shaft?
can i use type r ecu for this motor?
can i use OEM bearing?
Which is better fuel rail because i dont have one for it...
sorry i asked too much questions lol because Im making a list to get all parts to build my b18c1
Old Aug 31, 2010 | 08:40 PM
ruffrhyder's Avatar
Short ram intake with custom tuned tubing.
Eagle rods should be checked out by the machinist to ensure they are true.
Always a good idea to match valvetrain brand to the brand of cams. Other brand combinations will work though.
Stock type r ecu for stage 3 cams is a no no.
OEM bearings are ideal.
OEM fuel rail is more than adequate for an all motor build
Good luck with the build bro.
Old Aug 31, 2010 | 09:24 PM
I'm roughly 13+ compression. I have the Wiseco 8.25cc pistons which are around 14:1 compression but my chambers have been opened up so I'm thinking I'm somewhere around 13.5:1 give or take. Power wise the motor made 263 WHP and 163 TQ 85x89. Whole motor was built and tuned by PED Parris Engine Dynamics. You haven't built a 263 WHP B series motor did you? First motor he builds me yeld more power than all the builds you did... Go figure..... You're over there saying my builder is plain **** telling me to run 9's but hey his dyno don't lie.
Old Aug 31, 2010 | 09:37 PM
97dssi's Avatar
which do you like better? skunk2 or Brian crower for cam gears, camshaft, valve, spring, and retainer?
why cant you use type r ecu for stage 3? what would it happen? blow up the engine?
Old Aug 31, 2010 | 10:22 PM
Yes it will BLOW! Stop being a newb. Get the motor broken in and have a good tuner tune it. Please if you are really doing this build have an experienced builder who knows his stuff put everything together for you.
Old Sep 1, 2010 | 07:46 AM
ruffrhyder's Avatar
I never said your builder/tuner was "plain **** for telling you to run 9's"
Reread my post "If a tuner gave me a blank statement suggesting 7-9 heat range without thoroughly discussing the build, I would find another tuner immediately"
When building your motor, you and your builder should have had a CR and power goal in mind correct? If your CR and power goal were 13.5-14:1 and 260-270 whp then there is no way in hell I would think a heat range from 7-9 would be fine. With that CR and HP goal I would start off with a 8. Do some full throttle runs, pull and inspect the plugs. Then if need be, go a colder heat range. But like I said, to boldly state 7-9's are fine, that's simply absurd, there's a huge differnce from 7-9.
I also said "I'm with shodan. 7's have worked fine for most all motor builds. 99% of the all motor builds I've built with CR ranging from 11:1-13:1, hp ranging from 170-230 whp run perfect with 7's. Post pics of your plug's ground straps. I almost gaurantee you are running too cold of a plug."
Like I said 7's work fine for most all motor builds, not all. I primarily build daily driven motors, built to last with longevity in mind. First motor I ever put together 8 years ago made 202whp 139tq and had over 120k miles. The only reason for a rebuild was because when I sold the motor to a buddy he wanted higher CR, even when I opened it up, things were still in good condition. Obviously there are some full out builds dedicated to drag use, with 13:1 and up CR and hardly see idle and low rpm. For those applications then yes a 8 and up would be better than a 7. If that is your case, non daily driver, constant drag and high rpm then yes the 8-9's are perfect, but 7's would run too hot.
Throw some new 9's in your car, do a WOT pull then pull the plugs immediately and post pics. I'm curious to see your plugs. I'm not trying to argue that the 9's aren't working for you, I'm just saying I sure as hell wouldn't throw 7-9 in my car without planning and testing out which works best.
VTEC_Du_Ma_Mai
Oct 30, 2011 09:34 PM
97dssi
Sep 1, 2010 01:02 AM
mozzandherb
Aug 28, 2010 01:29 AM
Evans-Tuning.com
Jul 24, 2008 05:04 AM
Evans-Tuning.com
74
Jun 15, 2008 08:10 PM
