Which Brake Pads Do You Use?
Old Aug 30, 2010 | 06:48 AM
jdadams12's Avatar
Default Which Brake Pads Do You Use?
Just wondering.
Got 28K out of Wagner Thermo-Quiets on new Rotors.
Got new set and got 24k on machined rotors.
Wondering what to get next time. What has worked for you all?
Old Aug 30, 2010 | 08:53 AM
htekken's Avatar
Default Re: Which Brake Pads Do You Use?
believe i also use Wagner brake pads.
Old Aug 30, 2010 | 09:57 AM
F20B_accord's Avatar
i like ebcs but depends what type of driving you do but i believe any that you buy at like well here in canada its carquest or napa work well
Old Aug 30, 2010 | 02:58 PM
royalaccord92's Avatar
Hey I always use ebc green stuff but I drive pretty aggressively. I've also had really good experience with hawk hps and project mu but those were almost 200 just for pads. If you want longevity I would recommend a quality pair of ceramic brakes they will last the longest under "normal" driving condition and will give you less brake dust.
Old Aug 30, 2010 | 03:08 PM
CRZ1's Avatar
I changed my OEM front brake pad around 80k. I replaced with OEM pad 2 years ago, driving almost 20k now. I greased the sliding pin 2 weeks ago. Still has plenty life on the pads. I expect to change them at 160k
Old Aug 30, 2010 | 08:58 PM
nicolaselias's Avatar
Loved
Community Favorite
Currently using Hawk HPS (I drive VERY aggressively)
Formerly used Wagner Edge which is definitely one of the quietest pads I ever used.. Very good if that is what you prioritise..
Old Aug 30, 2010 | 10:00 PM
holmesnmanny's Avatar
I've used a lot of pads and so far Wagner Thermoquiet pads have been the best.
Old Aug 31, 2010 | 07:06 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Would not use EBC pads at all on a daily/slow car. Chances are they won't get hot enough to work effectively enough. I would only use EBC pads on an aggressively driven car.
OEM Honda pads would be ideal or whatever you can get!
Old Aug 31, 2010 | 08:12 AM
slamstrom's Avatar
OEM pads works just fine for daily commute.
Old Aug 31, 2010 | 12:33 PM
jdadams12's Avatar
I got some ceramics with the refund from my fast-to-wear lifetime wagners. Hopefully I can get more than 24K out of them.
Thanks.
Old Aug 31, 2010 | 12:50 PM
GhostAccord's Avatar
Had a set of OEM on for the last two years I ran the car. They were still good when I took my car off the road for the rebuild. Spirited daily driving .
jdmsta
Jun 4, 2012 10:42 AM
Lude454
Jul 17, 2005 09:59 AM
Aphelion
Apr 23, 2005 09:20 AM
DrummerDaveB
Sep 30, 2004 11:28 AM
GQ Cowboy
30
Jan 3, 2003 12:39 AM
