Need some help front the ls/vtec pros
Old Aug 29, 2010 | 07:52 PM
cleanazcoupe's Avatar
Default Need some help front the ls/vtec pros
hey guys i am trying to put together a reliable ls/vtec this is going to be my setup, i want to build something reliable and that makes fair power, if you guys suggest i change my setup please let me know what you would change. my setup will be.
B18b1 block 81.5mm
ACL race bearings
new main bearings
Ls crank
ls rods
arp rod bolts
arp head studs
p73 itr pistons
GSR head with a thinner headgasket for a bit more compresseion
Old Aug 29, 2010 | 08:40 PM
Do-Work's Avatar
Default Re: Need some help front the ls/vtec pros
what kind of cams and headers are you going with
Old Aug 30, 2010 | 10:31 AM
planning to do a built head but want to be able to run pump gas its going to be my daily
planning on like skunk 2 stage 2 cams with springs and retainers and a aftermarket intake mani
Old Sep 12, 2010 | 05:56 PM
im going to stick with the ls crank, what rods would you guys suggest to use gsr or ls??
Old Sep 12, 2010 | 08:33 PM
State.of.Prime's Avatar
With an LS crank you must use LS rods, or aftermarket ones. OEM vtec spec rods will not fit an ls crank at all. Vtec rods have 9mm bolts and your LS crank has 8mm holes for 8mm bolts, maybe someone has made some franken-mess of that, but if you want a reliable DD forget about putting in any rods from another crank.
Old Sep 13, 2010 | 06:50 AM
00Red_SiR's Avatar
All Motor Mentor
there are a couple links in this thread you'll want to check out:
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/all-motor-forum-%5Bfaq%5D-2628364/
Old Sep 14, 2010 | 02:06 PM
thanks alot guys
Old Sep 14, 2010 | 03:39 PM
DDTECH's Avatar
I do have a set of BNIB skunk2 tuner valvetrain and retainers if your looking for some.
spap3
Apr 7, 2010 12:45 PM
Black EH6
Mar 3, 2007 06:02 AM
bluemax189
Nov 21, 2006 06:25 PM
k e v i n
Jul 17, 2006 12:25 PM
FastAllmotorLsVtec
154
Aug 1, 2004 11:01 AM
