Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
k24 swap into LX civic.
Old Aug 29, 2010 | 06:46 PM
mr crick's Avatar
Default k24 swap into LX civic.
Has anyone on this site done this swap?
Old Aug 29, 2010 | 06:49 PM
Greg50Lt's Avatar
Default Re: k24 swap into LX civic.
Well if you dont have anyparts there are two ways to go about this. If you have the Funds I would just buy a block and head and take it to shop and let them do everything. Portwork, pistons ect ect. If your swapping might as well build. If you dont have funds. Buy the peices of the motor and then buy the internal parts later. You can also decide if you wanna do a turbo build or all motor build. Either way I suggest doing a 2.6 and fully built. Makes a **** ton of tq.
On youtube there was a vid of a guy who did it but I havnt seen a build thread on one. Your gonna need a new tranny as well so it could be pricey for you.
Old Aug 30, 2010 | 05:26 AM
ninaj9's Avatar
ummm y would you put a K24 into a LX Civic... thats a much heavier engine... i mean will it even fit? sounds like a lot of work... with lil results... your better off goin to junk yards ad findin a K20.. what year is this civic???
Old Aug 30, 2010 | 07:04 AM
Willie Mack's Avatar
Your gonna have to do more than just the motor. You are gonna have to do suspension work, drivetrain work and a **** load of other things too. If you have that part figured out and the funds, it would be pretty crazy to see this. GL with your build dude.
Old Aug 30, 2010 | 07:22 AM
K5^'s Avatar
K5^
Brand New
Originally Posted by mr crick
Has anyone on this site done this swap? I did a little searching but I couldn't seem to find much and I thought this would be faster. I'm planning on swapping a k24 into my 08 FA1. I'm in the planning and parts gathering stage and I thought it would be easier to talk to someone who might have done this already.
What junkyard are you going to find a usable K20?
Old Sep 1, 2010 | 05:22 PM
99blackcivicSi's Avatar
k20's stay in junkyards for minutes before they are snatched up anything useable and honda is gone in an instant. to the person who said the motor is heavier not really i have done shortblocks or longblocks on every k motor honda has, si, crv, accord, and of course some of those lovely cracked blocks the R series that the lx has stock not much heavier at all esspecially since wow well check this the manual trans is much lighter than the heavy **** auto trans so it kind of balances out :O wow cray how that **** works, you could honestly use most stock Si parts mounts and such harness kpro blah blah blah shouldn't be too much of a challange actually since its the same car as the Si when it comes down to it.
Old Sep 2, 2010 | 02:53 AM
Kidnkorner's Avatar
Extended down time? Car rental? If you are spending the cheese for all that surely the cost to rent an econo box for a week wouldn't be too much of a stretch.
Also, if you are building the engine internally surely you plan on tuning it right? I mean what fool completes a swap with a built engine, get in starts it up and drives it around before it's tuned? It should be towed to a tuner and started up on a dyno with a wideband lambda, tuned and broke in.
The 2.4 is slightly taller and will fit, you'll need a CRV mount to pull off the swap. From which side I can't recall.
Old Sep 2, 2010 | 07:02 AM
Greg50Lt's Avatar
Since you have a lx im guessing 2door. You should basically buy the pedal and everything that goes to a 2dr si. Hondata flashpro works great on k24s and its cheaper. I would suggest you buying either a full k20 motor with tranny ecu everything. Gonna be hard to find but will make life easier in the end. Then You can buy a 2.4 block and put that in at a later time, or just build the motor while its outta the car.
Old Sep 2, 2010 | 07:07 AM
Kidnkorner's Avatar
Stick with the flashpro utilizing your OEM ECU, sensors and wiring, you also get to keep AC and dash function.
Old Sep 2, 2010 | 08:36 AM
jksmith's Avatar
y cant you just pull everything you need from a 06+ Si, and just use your motor ?
Old Sep 2, 2010 | 09:11 AM
JDM FERIO RS's Avatar
Read my build thread it should help you out. Everything needed is there
Old Sep 3, 2010 | 08:16 AM
K5^'s Avatar
K5^
Brand New
do you mean an OEM si ECU? i have an LX CIVIC, it has an R18 engine in it. that is a sohc motor with an economy version of i-vtec. are you saying that the r18 and the k20 civic use the same ecu?
Hondata has Flashpro applicable to R18's.
Old Sep 3, 2010 | 08:35 AM
Kidnkorner's Avatar
You would have to run the ECU of the Si, and fairly certain the wire harness too. I was saying to stick with the CANBUS ECU of the K20Z3 because if you went with a K20A2 based ECU and Kpro you would have to sacrifice AC, cruise and dash function unless you wanted to run dual ecu set up. Keeping the K20Z3 architecture despite the DBW drawback will be the most cost effective straight forward set up.
I would just do a 2007+ K20A swap ordered from Steve at HMotorsonline.com with all the bolt on goodies and be done with it. I wouldn't tear down a block.
Old Sep 3, 2010 | 12:32 PM
Greg50Lt's Avatar
If your doing a transplant of this magnitude and the spare motor is going to be out of the car, why not just tear it down and build it up? Makes sense to me. I mean the OP could just trade in his lx and get a si for the price hes gonna pay for everything anyway.
Old Sep 3, 2010 | 02:26 PM
Kidnkorner's Avatar
Greg, tearing into a block poses potential reliability issues.
Forged pistons have their own issues, the ONLY reason I would tear into a short block is if I was looking to make more power than I could with bolt ons, or to install light weight connecting rods. The 2007 JDM K20A has 11.7 compression ratio and makes 225PS or 222BHP. With cams and all the bolt on goodies one can realize 260-280WHP easily. Any more than this in a FWD car you run into axles issues, traction issue, torque steer.
Old Mar 3, 2020 | 12:40 PM
Kenny Cole's Avatar
2001 honda civic or is the b20 a direct fit?
granny racer
Oct 4, 2009 12:48 PM
JDM_EK_wanabe
Jul 8, 2007 10:41 PM
1997 gsr
Feb 9, 2007 10:05 PM
Kelly.
Jan 5, 2005 11:08 AM
S
Nov 5, 2002 11:24 PM
