EG t bracket , half shaft HELp
Old Aug 29, 2010 | 11:31 AM
brooklynEG's Avatar
Default EG t bracket , half shaft HELp
hey guys im tryna finish up my build and alll i need is the bolts for my T bracket and for my Half shaft .. there gnna be bolting up to a Eg with an LS
i was wondering if anyone knew the sizes on the bolts or have photos of them so i can make sure i go get the rite ones !
Old Aug 29, 2010 | 08:14 PM
brooklynEG's Avatar
Default Re: EG t bracket , half shaft HELp
bumpp .. ineed this info asap anyonee can help me out pleaseeeeeeeeeeee
Old Aug 29, 2010 | 08:57 PM
honda_luvr_2000's Avatar
T-bracket bolts & washers part numbers:
rear bolt= 90165-S04-000, washer= 90505-SB2-000
front bolt= 90190-SR3-000, washer= 90505-SB2-000
two bottom bolts= 90188-SR3-010, washers= 90505-SR3-000
intermediate(half,jack,mid) shaft bolts part number= 90102-SF1-000 (x3)
Old Aug 29, 2010 | 09:02 PM
ricky00's Avatar
the bolt that goes to the back mount is a 17mm same one for the other side and the 2 bottom bolts are 19mm
Old Aug 30, 2010 | 07:33 PM
brooklynEG's Avatar
Thank you so much I needed this .. I can get my car finally running now :]
Nation5
14
Oct 5, 2016 02:27 PM
Tyler_EJ2
Transmission & Drivetrain
May 28, 2013 01:39 AM
delsolnewkid
Mar 11, 2006 04:12 PM
MeanGreenEG9
Jan 13, 2003 08:17 AM
MeanGreenEG9
Jan 10, 2003 07:15 PM
